type sh LSD vs a quaife LSD
Old Jun 26, 2004 | 09:56 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default type sh LSD vs a quaife LSD
i have 2 bad type sh trannys from 2 1997 prelude type sh's the gears and sycros are bad but the lsd diffs are still good are they as good as quaife lsd's or not?
Old Jun 27, 2004 | 07:48 AM
MugenPoweredLude's Avatar
sh trannies dont have LSD's in them
a LSD resides in the tranny case
you cant put it in the sh tranny case
the sh has a seperate unit called the ATTS
Old Jun 27, 2004 | 03:15 PM
raylude's Avatar
Default Re: (MugenPoweredLude)
then y do the sh and the base lude have different differentials ?
Old Jun 27, 2004 | 09:35 PM
Speedra500's Avatar
Default Re: (raylude)
because the type SH has ATTS
Old Jun 28, 2004 | 05:50 PM
Gerhard_001's Avatar
Default Re: (Speedra500)
the differentials are different for ATTS purposes. Just for future purposes ATTS is a yaw control system, that means that when you turn the wheels up to 80% of torque is tranferred to the outside wheel. the car knows this through speed sensors that measure the speed of the vehicle, the cornering force of the vehicle and the angle at which the wheels are turned at of which are controlled through an ECU dedicated to the ATTS system. Under straight line acceleration ATTS is silent and does not split the power evenly between the two wheels. LSD splits power evenly between the two wheel under straight line acceleration and cornering mechanically.
buffgsr
Sep 1, 2008 09:40 AM
us31wking
Aug 1, 2008 06:48 PM
uleiro
May 19, 2008 05:58 PM
Sam
Apr 1, 2003 11:24 AM
Wo-Nelly
Jun 18, 2002 05:02 AM
