i got a line input converter thing and the wires and i wanna run a stock head unit
Old Jun 26, 2004 | 08:53 PM
honda_S's Avatar
Default i got a line input converter thing and the wires and i wanna run a stock head unit
where do i connect the remote wire and can you link me to a thread on how to take out my hu in a 99 civic
do i need to take it out?
Old Jun 27, 2004 | 12:15 AM
honda_S's Avatar
someone please help
Old Jun 27, 2004 | 07:36 AM
B18C_EJ8's Avatar
I install line out converters behind the deck 99% of the time for 2 reasons. One, because it's cleaner tapping wires there rather than at the rear speakers, and Two, because if you ever upgrade your deck in the future, you don't need to run RCA's to the back, because they're already there....
As far as your remote wire, you can grab switched 12v behind the radio, too. Otherwise, just tap a switched 12v at the fusebox...
Old Jun 27, 2004 | 11:25 AM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I install line out converters behind the deck 99% of the time for 2 reasons. One, because it's cleaner tapping wires there rather than at the rear speakers, and Two, because if you ever upgrade your deck in the future, you don't need to run RCA's to the back, because they're already there....
As far as your remote wire, you can grab switched 12v behind the radio, too. Otherwise, just tap a switched 12v at the fusebox...</TD></TR></TABLE>
What he said also hondas have a acc. term on fuse box. 94
Old Jun 27, 2004 | 12:25 PM
honda_S's Avatar
well i dont ever plan on upgrading the deck so ill just run it behind and that leaves my last question does my hu need to come out for this?
thanks guys your guys are helping alot
Old Jun 27, 2004 | 02:55 PM
fcm's Avatar
fcm
Old Fart
Default Re: (8y61d)
You may be able to unplug the harness without removing the HU, but its better to remove it
All you need is a phillips [star] screwdriver, remove trim from under unit ,locate 2 backbrace screws , remove, pull HU out.
hope this helps.94
CPreston
Audio / Security / Video
Mar 5, 2010 06:28 AM
defaced8
Apr 20, 2008 11:42 AM
DjBristO
Mar 6, 2006 10:06 AM
imadigitalgod
Oct 5, 2004 12:39 PM
wanna b R
May 24, 2004 08:10 AM
