Shaving Antenna, Wipers, Etc.
I want to shave a few things off the car for a clean look.
I know I want to weld in metal, but am unsure how to go about it.
When putting the metal in place do I need to cut it to the size of the hole I'm trying to fill? Then clamp and weld?
What do I use to grind down the welds?
thanks for the help......i didn't ask how it would look i asked it was done
and i think shaving the rear wiper and antenna will look just fine thanks
wow, chill guys people do this all the time to there ED's no need for a wiper and the antenna is in a pretty shitty spot.
its not like he is Shaving the sidemoldings or anything.
bump because i would like to know how to do all this too.
yeh, no handles is too naked to me, but no keyholes is just right. rear wiper removed b/c hatch falls and hits me in the head, antenna, i like....but drip rails might get filled in w/metal
they barely hold water anyways, might as well get them gone and fill it flush
i'm pretty sure you cut metal to fit, tack weld it, be careful not to overheat it, then grind welds down and use filler to make it perfect
All you do is cut the metel so its as big as the hole. Tack it in a few spots so it doesnt move, then weld around the rest so that it doesnt have any gaps. Then grind the welds down smooth.
I actually made my metal plate exactly the same size as the hole on the antenna, and used a magnet to hold it on there while i tac welded it. Finished the weld and ground it all down smooth then body filled the rest. Its fairly easy if you can weld decent enough.
OldSchoolHatch
Nov 24, 2002 10:29 AM
