Top speed on h23 gearing...
Old Jun 26, 2004 | 05:09 PM
2.2XDreams's Avatar
Default Top speed on h23 gearing...
i know that the M2F4 has a 5th gear of .870 and a final drive at 4.266, but how much of a bump in top speed would one get if they were using an h23 tranny which has a .812 5th gear with the same FD? thanks
Old Jun 26, 2004 | 05:54 PM
Nikoli's Avatar
Default Re: Top speed on h23 gearing... (2.2XDreams)
i maxed out at 140mph @ 6500rpm
i think you run out rpm's before the gear runs out. someone correct me if im wrong. id like to know also.
Old Jun 26, 2004 | 06:13 PM
flip1199's Avatar
Default Re: Top speed on h23 gearing... (95deckedlude)
where does 4th gear run out?
Old Jun 26, 2004 | 06:17 PM
Nikoli's Avatar
Default Re: Top speed on h23 gearing... (flip1199)
i think 4th runs out at about 100 or so
Old Jun 28, 2004 | 04:16 PM
2.2XDreams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">i maxed out at 140mph @ 6500rpm
i think you run out rpm's before the gear runs out. someone correct me if im wrong. id like to know also.</TD></TR></TABLE>
this would be on an h22 though, so how fast would someone be going at redline in 5th?
Old Jun 28, 2004 | 04:18 PM
Nikoli's Avatar
no... this would be on an h23
Old Jun 28, 2004 | 04:32 PM
H23 Power's Avatar
you must have some big tires on the car, cause a stock SI shouldn't be goin any faster than 130 at 6500 rpms
Old Jun 28, 2004 | 04:36 PM
2.2XDreams's Avatar
no... this would be on an h23</TD></TR></TABLE>
sorry for misunderstanding... i want to swap an h22 into an eg, and because im thinking about boosting it, i want to take advantage of longer gears. so instead of using an m2f4, i would use an m2s4. im just trying to get an idea of how give the difference in top speed will be.
Old Jun 28, 2004 | 04:37 PM
Nikoli's Avatar
Default Re: Top speed on h23 gearing... (H23 Power)
yea that was on 17"s
Old Jun 28, 2004 | 08:05 PM
crdcz03's Avatar
Fortune Cookie Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2XDreams &raquo;</TD></TR><TR><TD CLASS="quote">
sorry for misunderstanding... i want to swap an h22 into an eg, and because im thinking about boosting it, i want to take advantage of longer gears. so instead of using an m2f4, i would use an m2s4. im just trying to get an idea of how give the difference in top speed will be.</TD></TR></TABLE>
care to share why you would need that kind of speed?
if you want long gears get a 4th gen accord tranny lmao
Old Jun 28, 2004 | 09:58 PM
Nikoli's Avatar
Default Re: Top speed on h23 gearing... (crdcz03)
actually the h23 has longer gears than the h22
Old Jun 29, 2004 | 05:10 AM
Honda318dx's Avatar
Where do you plan on going over 140mph in your hatch.. We can't answer your question without knowing your max RPM and tire size..
Old Jun 29, 2004 | 06:12 AM
LudeyKrus's Avatar
Well, assuming you use the same size tire as on a Prelude, and you are using the H23 tranny on an H22, then you will hit fuel cut at 7600 while running 152mph.
I got bored in class one day and calculated out all the top speeds w/ the different motor/tranny combos in the Prelude.
Old Jun 29, 2004 | 09:14 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">yea that was on 17"s</TD></TR></TABLE>
Yeah, because i'm at 6000 at 120mph with 15's.
Old Jul 10, 2004 | 08:47 AM
pArAdOxsqUArE's Avatar
i maxed out 135 with my h23 all stock. ???
Old Jul 11, 2004 | 11:09 PM
leprekhan's Avatar
Default Re: (LudeyKrus)
noting to deal with the current topic what info bout a h23jdm can u give me what kinda cams, cam gears, fuel rail, injectors, pistons, crank, such did u use. n where can u find that ****
Old Jul 12, 2004 | 08:56 AM
Nikoli's Avatar
Default Re: (leprekhan)
no such thing of a jdm h23
Old Jul 12, 2004 | 10:26 AM
Ataraxia's Avatar
Default Re: (Deckedlude)
I'm at 127mph at 6500 rpms in my stock 92 Si, (stock wheels). The H22 has fuel cut off at 7600 rpm. I hope that helps. Top speed does matter, I feel ya.
Old Jul 12, 2004 | 10:38 AM
ludetech
Guest
Posts: n/a
this doesnt make sense if the h23 has longer gears than the h22. I've hit 144 and I still had a few hundred more rpms in my h22. Im on 18's with 35 series tires.
Old Jul 12, 2004 | 10:49 AM
Ataraxia's Avatar
Default Re: (ludetech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludetech &raquo;</TD></TR><TR><TD CLASS="quote">this doesnt make sense if the h23 has longer gears than the h22. I've hit 144 and I still had a few hundred more rpms in my h22. Im on 18's with 35 series tires.</TD></TR></TABLE>
Because you have larger wheels, and more rpm before the red line.
Old Jul 12, 2004 | 02:27 PM
H23 Power's Avatar
Default Re: (Jonas427)
wheel size doesn't matter....its tire size
Old Jul 12, 2004 | 02:28 PM
H23 Power's Avatar
because you have an H22 with a higher redline.
pkolaboy
Apr 15, 2008 10:01 AM
h22_crx
Jan 25, 2007 03:25 PM
gospeedracerh23
Mar 8, 2006 04:28 PM
s.cali alan
Oct 24, 2004 08:46 PM
sloaccord
May 20, 2004 03:52 PM
