Weird problems
I have a 91 dx hatch i changed the rear brakes to 92 integ disc.Now when it rains i have no traction in the back the rear sways like crazy.When its dry the rear make a humming noise like the tires arnt balance but they are and i have had 4 diff. rims and tires on it.I have the car lowered on h&r springs if that makes a difference.Any help would be appreciated
Same car i have a jdm sohc vtec motor in,when the car warms up it stumbels on acceleration and has a lose of power.When the car is cool it runs fine and doesnt do this.I have replaced the rotor,cap,plugs and wires.I thought it might be the injectors so im changing them next week.
as far as the motor goes it sounds like you have wiring issues either with fuel or a sensor.
the rear swaying thing is probably due to alignment, the fact that you don't have the same tires on any of the corners might make a significant amount of road noise. And I would have to say that no, the H&R's have nothing to do with this.
G2IntegraGS
89
Dec 5, 2019 05:53 AM
