Sloppy Shifter Need Help
Old Jun 26, 2004 | 08:07 AM
hondaless's Avatar
Default Sloppy Shifter Need Help
Ok, i just bought a 93 Civic Ex for my fiance for $1000, with just a couple rust bubbles and the car was taken care of very well. Here is one problem with it though. When you go into gears you can still move the shifter around a lot almost as much as when you are in neutral. I just Put on the Energy Suspension shifter bushings and it didn't help at all. All it did is i can find the gears a little easier. I don't remember my CRX's having this much play. Any advice would be apreciated. Thanks
Old Jun 26, 2004 | 09:47 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Sloppy Shifter Need Help (hondaless)
the bolt and nut that goes through the bottom of the shifter and shift linkage needs to be tightened. that will get rid of the sloppiness.
Old Jun 26, 2004 | 09:55 AM
bbarbulo's Avatar
Default Re: Sloppy Shifter Need Help (AzntaggeR)
check the bitch pin too, if that was ghetto-rigged, you'll need some attention there.
Old Jun 26, 2004 | 09:57 AM
deeksmooth's Avatar
check the pin that connects your linkage to the trans. if its a bolt or not the right pin it may cause 'sloppiness'. i had a bolt/nut through mine temporarily and had the same issue. when i replaced it with the proper pin, it cleaned right up.
in this pic, the pin is part no 28 & the pin 'ring' (holds the pin in) is part no 28
Old Jun 26, 2004 | 10:54 AM
hondaless's Avatar
Thanks for the advice I will check it as soon when i get some more time. Ill tell ya how it goes.
Old Jun 26, 2004 | 11:00 AM
RCautoworks's Avatar
See the joint by 28, thats what caused the problem. The people at rpiracing.com actaully came up with a solution to it.
Old Jun 26, 2004 | 11:22 AM
hondaless's Avatar
Default Re: Sloppy Shifter Need Help (citrEK)
Well i guess its somewhere in the shifter assembly, all the linkages are ok. So I guess ill just have to live with it for now.
Old Jun 26, 2004 | 11:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaless &raquo;</TD></TR><TR><TD CLASS="quote">Well i guess its somewhere in the shifter assembly, all the linkages are ok. So I guess ill just have to live with it for now.</TD></TR></TABLE>
Not sure if you read what I put above but thats the problem.
Old Jun 26, 2004 | 12:16 PM
hondaless's Avatar
Default Re: Sloppy Shifter Need Help (90blackcrx)
I had my dad put the car in gear and move it side to side the connection to the Trans and the stabalizer bar moved very very little like 2mm. All the play is coming from inside the shifter assembly. I could see if where that pin was everything was woling around but everything was really tight. So the prbblem is inside the shifter itself.
Old Jun 26, 2004 | 12:24 PM
Dancing is Forbidden's Avatar
Look into getting some ES Shifter bushings. Could be those too.
Old Jun 26, 2004 | 12:33 PM
hondaless's Avatar
Default Re: Sloppy Shifter Need Help (lsvt3c)
I put in the ES shifter bushings this morning...the stabalizer shifter bushing was shot. But it didn't cure the problem.
Old Jun 26, 2004 | 12:37 PM
Its the joint
Old Jun 26, 2004 | 01:15 PM
phobi9's Avatar
Yeah my shifter moves side to side a bit when in gear, doesn't make any noises - I thought that was 'normal' or a slight wear issue.
So it's not supposed to be like that? And the problem is...?
Old Jun 26, 2004 | 01:17 PM
Default Re: Sloppy Shifter Need Help (phobi9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phobi9 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah my shifter moves side to side a bit when in gear, doesn't make any noises - I thought that was 'normal' or a slight wear issue.
So it's not supposed to be like that? And the problem is...? </TD></TR></TABLE>
Does anyone read anything anymore ??????
ITS THE JOINT
Old Jun 26, 2004 | 01:45 PM
ahh sanga's Avatar
my car does this too...would a short shifter fix the prob?
Old Jun 26, 2004 | 01:50 PM
ej1 pilot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">the bolt and nut that goes through the bottom of the shifter and shift linkage needs to be tightened. that will get rid of the sloppiness.</TD></TR></TABLE>
i believe its a 12, just get under your car and keep tightening it and feeling the gears til its at your liking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinusang &raquo;</TD></TR><TR><TD CLASS="quote">my car does this too...would a short shifter fix the prob?
no a short shifter will not make a difference in that, the bolt determines the mobility
Old Jun 26, 2004 | 02:24 PM
the jdmchop's Avatar
WOW
i guess some poeple dont read the whole thread?
how did they fix the problem? develope a new joint?
now i have a soild answer for y those sumana bitchez get sloppy
Old Jun 26, 2004 | 02:46 PM
ej1 pilot's Avatar
Default Re: Sloppy Shifter Need Help (jdmchop)
^^^ it could ALSO be the bolt, mine was too loose and i tightend it up and problem solved...theres not one solution to everything
Old Jun 26, 2004 | 03:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop &raquo;</TD></TR><TR><TD CLASS="quote">WOW
You got that one right, they replaced the joint with one they bought. They said it was a really nice feel afterwords. It was costly though.
swizz977
Nov 22, 2011 07:34 PM
JDMPR
Sep 21, 2009 06:11 PM
Juice-UP
Mar 4, 2009 08:24 AM
90Integra
Apr 25, 2005 08:47 PM
egg_baLLa
24
Aug 19, 2004 08:59 PM
