What injectors should I get?
Old Nov 17, 2001 | 02:58 PM
mafay2's Avatar
New User
Default What injectors should I get?
I currently running TODA specB package together with a Yoshio reprogrammed ECU. According to my Greddy A/F meter reading, I have to add 10-15% fuel with the VAFC just to make it run NOT extrmely lean. I heard that it is not a good idea to add that much fuel with the VAFC alone and the stock injector probably max out already. So I am thinking of buying a bigger injector.
So which injector would you guys recommend? I am thinking of either the Prelude injector or the RC 310cc one. Also, I would get a FPR and goto a dyno next spring to have it tune.
If I get the RC310cc one, will I need to have my ECU reprogram again or a FPR, VAFC, and some dyno time will help it tune in?
Finally, where can I get a good deal on those injector?
Old Nov 17, 2001 | 06:09 PM
Hybrid ctr's Avatar
Default Re: What injectors should I get? (mafay2)
I think you should get the RC 310cc injectors
along with a fpr from AEM, SX or Aeromotive
I think a fpr and vafc would do the trick
Old Nov 17, 2001 | 07:56 PM
mafay2's Avatar
New User
Default Re: What injectors should I get? (Hybrid ctr)
Thanks, did the RC 310cc one have the same spray pattern as the stock one and is it direct bolt on to the stock fuel system?
Old Nov 17, 2001 | 07:58 PM
Hybrid ctr's Avatar
bolt on
mannyman
14
Apr 5, 2005 09:10 PM
b20turbojason
Aug 7, 2004 04:58 PM
Kack
Jan 31, 2004 05:48 AM
Black R
Mar 1, 2002 12:18 PM
mafay2
Nov 26, 2001 08:33 PM
