what axles??????
Im not sure if im in the right forum but my cv joints in my axles are getting really bad and i was wondering if 94-97 teg axles would fit on my crx w/ a cable j1 tranny and 90-93 teg front brake and hub assembly, also what is the average price for a knock sensor for a gsr motor
94-up axles will work on your carr, but...if you already ahve the stock axles and 1/2 shaft for that year motor then it will not work..casue your year axles uses a FEMALE type 1/2 shaft...while the 94-up or 99-00 si or sir2 uses a MALE type 1/2 shaft.
you could use them if you get the 1/2 shaft corresponding to it.
so best bet is jsut to get he same year axles for your car/motor.
currently i have a cable j1 tranny with 90-93 integra front brake and hub assembly with integra 90-93 axles, a freind said he'll give me his 94 and up axles and half shaft if I could use them so i'm trying to fing out if it will be a hassle to swap them out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twin rex’s »</TD></TR><TR><TD CLASS="quote">currently i have a cable j1 tranny with 90-93 integra front brake and hub assembly with integra 90-93 axles, a freind said he'll give me his 94 and up axles and half shaft if I could use them so i'm trying to fing out if it will be a hassle to swap them out</TD></TR></TABLE>
nope it fine..it the same..but like i say the 1/2 shaft need to correspond with the axles. but if you getting both the axles and 1/2 shaft then you're fine.
