B16 Swap
Old Jun 25, 2004 | 10:44 PM
civiceg500's Avatar
Default B16 Swap
Can you use a 92-95 civic ex vtec wiring harness on a JDM B16A2 with a P30 in a 95 civic dx or do i need something else.
Old Jun 25, 2004 | 10:55 PM
Combustion Contraption's Avatar
yeah, that will work.
Old Jun 25, 2004 | 11:32 PM
JDMlyfestyle's Avatar
There is no such thing as a JDM B16a2. JDM motors do not have #'s after the letters. so if its a 2nd gen it would be the B16a SIR II. and yes the harness and ecu will work but u have to wire up a knock sensor other wise u will have a CEL
Old Jun 26, 2004 | 06:07 AM
civiceg500's Avatar
Default Re: (JDMlifestyle)
Thanks for the info, JDM SIRII gottcha. Where can i get the knock sensor and wires or and i better off getting a Hasport sub harness for my DX harness?
Old Jun 26, 2004 | 06:36 AM
2lua's Avatar
Default Re: (civiceg500)
your motor came with a knock sensor already on the block. save your money and run the 3 wires (vtec soleniod, vtec pressure switch sensor and knock sensor), but if you wanted spend money the get the sub harness.
Crxh22ajdm
Dec 21, 2012 01:55 AM
vtec maniac
Jul 27, 2010 10:41 AM
bustah49
May 11, 2007 07:57 AM
daklown
11
Oct 13, 2003 06:12 AM
Prevail
12
Jan 2, 2003 04:49 AM
