HELP!!!!! 91 CRX dash in an 89 hatch?!
Old Jun 25, 2004 | 10:36 PM
Smooth89Hatch's Avatar
Default HELP!!!!! 91 CRX dash in an 89 hatch?!
i was wondering if the dash out of a 1991 CRX, with the seatbelts on the door, would fit into my 89 dx hatch that has the seatbelts bolted to the car. PLEASE , if you have any info.......let me know. thanks.
Old Jun 25, 2004 | 10:41 PM
87b16crx's Avatar
Default Re: HELP!!!!! 91 CRX dash in an 89 hatch?! (Smooth89Hatch)
it will fit just fine man. i have a 91 hatch and i have the belts in the pillar and a crx dashboard. just use all the parts that go with the crx dash
Old Jun 25, 2004 | 10:47 PM
Default Re: HELP!!!!! 91 CRX dash in an 89 hatch?! (87b16crx)
thanks. like what parts to be specific?
Old Jun 25, 2004 | 11:23 PM
bump for info
Old Jun 25, 2004 | 11:34 PM
4DRmafia's Avatar
all the parts that is on the dash and the console and make sure u use the crx steering cover too
Old Jun 26, 2004 | 12:51 AM
NickFury's Avatar
the seat belt doesn't have anythign to do with converting the crx dash to your civi HB..i have done this one too many time..fit perfectly and basically the same shyt.
since your car is an 89 HB with the seat belt on the pillar. you need to get all these from the 91 crx.
dash
cluster cover
steering column cover
center console
center vent
dash wiring under the cluster
because of the differences in the HAZARD button location and plug you need them.
and from there on it jsut plug n' play. very simple mod to your HB.
also if you can get the climate control get that if you want to convert you a/c to the crx which is motorized, not like the civic which use the cable. then you would need to get either the whole heater core/blower or you can jsut get the motor from them. and then install them onto your civic one.
Old Jun 26, 2004 | 10:30 AM
Default Re: HELP!!!!! 91 CRX dash in an 89 hatch?! (NickFury)
thanks peeps. it'll really help.
Old Jun 26, 2004 | 03:01 PM
Grnnt4
Sep 10, 2010 07:56 PM
brandIZZLE!
Nov 29, 2007 12:01 PM
jdmEF8racer
Oct 6, 2006 04:44 PM
Down Shift Motoring
Dec 22, 2005 02:38 PM
90hatch2fast2pass
Jul 5, 2003 09:30 PM
