very wierd tdc problem...
Old Jun 25, 2004 | 09:38 PM
fullracegsr's Avatar
Default very wierd tdc problem...
ok so i finally got the cams from a friend to complete my parts need list... throw itr cam gears i had lying around on... went to set cams to tdc... the pin holes and gears dont line up... i can get either one to line up but not both at one time... i am baffled... can anyone help me out... when the pinholes are lined up the ex. cam gear points way towards the front of the car like 2 teeth off... with the gears lined up the pin holes is a little off the hole in the rail... its more pointing toward the spark plug holes... i dont understand it... i need help im at a stand still...
Old Jun 26, 2004 | 04:13 AM
Default Re: very wierd tdc problem... (fullracegsr)
to the top
Old Jun 26, 2004 | 05:57 AM
OH BTW... this is a gsr head and what are believed to be gsr cams... if i had b16 cams would the holes and gears all line up?? im going to pull the cams and check them against the pics i have when i get home
Mad-Mike
May 31, 2011 02:29 AM
danmej1
Jun 17, 2010 10:34 PM
TurboJdmEF9
May 26, 2006 02:16 PM
Sam1am26
Apr 14, 2004 10:52 AM
tuan...
Jan 27, 2004 07:52 PM
