installed shift light with rpm switch now no tach why not??? help please
Old Jun 25, 2004 | 09:16 PM
B16Civic93's Avatar
Default installed shift light with rpm switch now no tach why not??? help please
i installed a shift light that i had in my civic its a 93 ex i used an rpm activated switch to activate the light, i followed the directions, however i hooked the rpm wire to the back of the gauge cluster tot he tach and the tach stopped working, then when i disconnected the wire the tach worked again. do you know why? does anyone have any experience with the rpm activated switch taht could tell me exactly where i can take the rpm side off of?? any help is appreciated thanks in advanced
Old Jul 27, 2005 | 06:28 PM
BROKE.eg's Avatar
Default Re: installed shift light with rpm switch now no tach why not??? help please (B16Civic93)
bump for this question, im havin the same problem.
Old Jul 27, 2005 | 06:33 PM
chad's Avatar
Moderator
not enough power to power both tach and aftermarket tach!!
tap in at the dizzy....
Old Jul 27, 2005 | 06:35 PM
BROKE.eg's Avatar
Default Re: installed shift light with rpm switch now no tach why not??? help please (chad)
i dont think thats it, i think it has something to do with the negative switch on the rpm thing. cause ive ran several shift light from the same place.
Old Jul 27, 2005 | 06:59 PM
chad's Avatar
Moderator
Default Re: installed shift light with rpm switch now no tach why not??? help please (BROKE.eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BROKE.eg &raquo;</TD></TR><TR><TD CLASS="quote">i dont think thats it, i think it has something to do with the negative switch on the rpm thing. cause ive ran several shift light from the same place.</TD></TR></TABLE>
cut line?
Old Jul 27, 2005 | 07:00 PM
BROKE.eg's Avatar
nope
Old Jul 27, 2005 | 08:38 PM
BROKE.eg's Avatar
anyone
Old Jul 27, 2005 | 08:41 PM
Deemeetree's Avatar
Electrician
Maybe the shift light bypasses the RPM signal to your cluster in order to fully have a 100% signal to the light?
Old Jul 27, 2005 | 08:48 PM
BROKE.eg's Avatar
Default Re: (Deemeetree)
but the light doesnt light up either
this is how i have it hooked up
RPM SWITCH
red-12v switched
black-ground
yello-to ground wire on light
white-tach wire
LIGHT
red-12v switched
black-yellow wire on rpm box
Old Jul 27, 2005 | 08:50 PM
A.E Motoring's Avatar
Default Re: (BROKE.eg)
just tap it into the dizzy...thats where most tachs and **** are wired up to
Old Jul 27, 2005 | 08:52 PM
BROKE.eg's Avatar
Default Re: (SPNFEDEJ)
im getting signal from the tach, i doubt tapping into the same wire 3feet away is gonn amake a diff. shoudl i be using a relay?
Old Jul 27, 2005 | 08:53 PM
your getting a signal? which means when you rev it the light goes off right? but the cluster isn't moving?
Old Jul 27, 2005 | 08:56 PM
BROKE.eg's Avatar
no the light doesnt come on either, the rpms arent activating the internal relay
http://autometer.com/tech_instructions.aspx?sid=6
pick wat works for you and follow the directions
Old Jul 27, 2005 | 09:00 PM
BROKE.eg's Avatar
im pretty sure i need to use a relay
Old Jul 27, 2005 | 09:03 PM
well if thats wat it says...GL
Old Jul 27, 2005 | 09:06 PM
BROKE.eg's Avatar
it doesnt really have instructions for what im doin. im not hookin it to a shift light im just using a auot light bulb.
Old Jul 28, 2005 | 07:41 AM
BROKE.eg's Avatar
up
ATS*Mark
Jun 27, 2007 12:47 PM
SiR Inspired ED7
Oct 5, 2005 05:40 AM
Smokinsax
Jun 12, 2002 11:52 AM
IgniteTeg
Aug 29, 2001 07:25 PM
