Tranny Fluid quick HELP!
just un-bolt the VSS (1 10mm bolt) on the backside of the tranny by the fire wall. and pull out the whole VSS unit, and you can just poor the fluid in there
theres a bolt right behind the passenger axles on the tranny. that is the fill bolt, if you fill it up at the vss you might overfill it and might cause damange to your tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller »</TD></TR><TR><TD CLASS="quote">theres a bolt right behind the passenger axles on the tranny. that is the fill bolt, if you fill it up at the vss you might overfill it and might cause damange to your tranny.</TD></TR></TABLE>
Ok this way is for the *smart* people who know how much tranny fluid to put in
trooper0641
Feb 4, 2005 04:15 AM
