B16A JDM swap givin me CRAP
Old Jun 25, 2004 | 08:16 PM
HondaGuru23's Avatar
Default B16A JDM swap givin me CRAP
I swapped in a JDM B16A into my DX Civic. My fuel psi. is at 30-32 (which is a little low), my stock tach won't sit still even though I'm not even touching the throttle, my engine surges at idle after you rev up, and my A/F meter reads max rich and never moves!!! Man I'm annoyed! What I need to know is does anyone think it could be my ECU, it's a chipped P30, or any other suggestion would help; My psi problem will be cured with an adj. fuel psi regulator; the tach thing is just mind numbing, don't know there; and the A/F meter, I need to know exactly what wire I need to run to the O2, but I've just replaced so colors are different so if I can get the color of the wire that is on the harness that the O2 connects to, that would be great (4 choices: ORN/BLK, GRN/WHT, WHT, or YEL/BLK. Please help, my sanity is on the line, and there's a punk in a stang waiting to race. E.
Old Jun 25, 2004 | 08:25 PM
handa's Avatar
Default Re: B16A JDM swap givin me CRAP (HondaGuru23)
you have CEL?
Old Jun 25, 2004 | 08:29 PM
Default Re: B16A JDM swap givin me CRAP (handa)
CEL?? as in cell phone number?
Old Jun 25, 2004 | 08:30 PM
handa's Avatar
CEL=check engine light:
Old Jun 25, 2004 | 08:32 PM
Sorry, no I don't, but then again I can't be sure, I think the bulb's burnt. Sorry if I don't know the abbreviations, but I'm not really a forum guy. The people here are my only and probably final hope?! Please help.
Old Jun 25, 2004 | 08:50 PM
B_CRUZ!'s Avatar
to tell if its burnt out, put the key in the ON position and it should light up for a few seconds.
try a buddies ECU.
bleed your coolant. clean youor IACV... it could be many things.
Old Jun 25, 2004 | 09:15 PM
HighRevn's Avatar
Default Re: B16A JDM swap givin me CRAP (B Cruz)
My buddy just had the same problem, check the IACV, thats probably the culprit
Old Jun 25, 2004 | 10:24 PM
beaterdriver's Avatar
CEL is more or less a universal term
Old Jun 25, 2004 | 10:26 PM
some chipped ecu's do make it rev up and down till the engine is at operating temp. i seen it, it is weird
Old Jun 26, 2004 | 07:29 AM
articbluedc5's Avatar
Default Re: (beaterdriver)
I had the tach problem, it ended up being a wire coming from the distrubutor, I beleive the blue wire, i wasn't in good enough not making the contact
Old Jun 26, 2004 | 07:53 AM
drewlee's Avatar
Default Re: (94CarbonHatch)
I connected my air/fuel to the orange/black wire and it has worked great. As for the surging thing, my car did the same thing but it ended up being a map sensor problem and once I had that fixed it ran like a champ.
good luck
Old Jun 30, 2004 | 02:31 AM
Thanks, everyone.
justin1785
Mar 14, 2011 09:03 AM
Jose-aka-Pedro
May 30, 2006 03:57 PM
JDMHatch101
Aug 22, 2003 07:36 AM
slowpokesi
25
May 27, 2002 07:01 AM
