Harness guru's I need your help answering a question
i not really sure what harness i should buy.. i have a 0bd0 block and odb2 head and my car is odb1 .. what should i do?? i pretty should the head doesnt matter.. my main corcerns are the sensors on the back on the block..... i 100% sure i have to buy a odb1 harness, but should i buy a odbo harness also??
use your existing eh3 engine harness. and add accordingly.
the sensors on the back of the block are real easy and pretty much the same as far as obd0-1 .
youll have the one pin bullet style plugged sensor which wont need to be touched,
then you have the fan switch which is right beside the above mentioned plug, this is orignally on your water neck on the eh harness. so it will need to be extended and plugs changed.
then you have the knock sensor which is the uppermost plug on the back of the block. which will need to be wired in directly to the ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">
then you have the knock sensor which is the uppermost plug on the back of the block. which will need to be wired in directly to the ecu.</TD></TR></TABLE> my eh3 is gone, i'm planing to buy a harness from any 92-95 civic or 94-95 teg
whats plugs are differnt on a odb1 motor and obd0 motor?.. do u have any pics.. i will take pics 2morrow!
