howstuffworks.com wrong on fuel injection
Old Jun 25, 2004 | 04:43 PM
budlight's Avatar
Default howstuffworks.com wrong on fuel injection
Quote:
From this example, you can see how the control system makes adjustments. With parameter B as the level of oxygen in the exhaust, the lookup table for B is the point at which there is (according to engine designers) too much oxygen in the exhaust; and accordingly, the ECU cuts back on the fuel. http://www.howstuffworks.com
Now, on the last sentence where it says where there is too much oxygen in the exhaust; and accordingly, the ECU cuts back on the fuel. I think this statement is incorrect, it shoud say something like if there is too much oxygen in the exhaust then the ECU will add more fuel.
If the combustion process isnt using all oxygen, then more fuel should be added to go with the oxygen not being used. The only situation i can think of where you would want to cut back on fuel is if you were running extremely rich and combustion could not occur because the spark plugs are fouled or something. The misfire monitor would detect the unequal powerpulses and go into limp mode of something. Is howstuffworks wrong or do i have it messed up?
basilwatts
Honda Ruckus and Scooters
Dec 12, 2017 08:26 PM
Lquin
Nov 5, 2011 06:01 AM
91CivicEF
Jan 20, 2009 12:05 AM
t0ekn3e
Jan 27, 2006 12:43 AM
