Integra Type R Front Lip
Old Jun 25, 2004 | 04:21 PM
Full Intensity's Avatar
Default Integra Type R Front Lip
Will an OEM Integra Type R front lip fit onto a 92 to 95 Civic coup? thx.
Old Jun 25, 2004 | 04:23 PM
hybridhondasquad's Avatar
i would like to know also but from my experience it didnt work
Old Jun 25, 2004 | 04:25 PM
reason being is i threw out my old lip after i replaced the front end from an accident and didn't buy a new one cause i wanted something a lil bigger (the type r one) i can get an aftermarket type r (oem) for 60 bucks i think, to get one made for a civic im looking at 130
Old Jun 25, 2004 | 04:46 PM
Padawan's Avatar
Darth ModerVader
Default Re: Integra Type R Front Lip (Full Intensity)
The bumpers of the two cars are completely different shapes, not to mention the fact that there are even two different ITR lips depending upon the year ('97 vs. '98+). Do yourself a favor and buy a lip that was specifically designed for your car. You'll be much happier with the result.
Old Jun 27, 2004 | 04:02 PM
Old Jun 27, 2004 | 06:42 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Full Intensity)
I understand that you want to save money, but again, the ITR piece won't fit correctly on your car. You really need to purchase one that is correctly designed for your application. Also understand that with body pieces, to a certain extent you get what you pay for, and the poor fitment found with many cheap pieces is generally not worth the money saved on them. A well-made piece will save you a lot of headaches with the installation and fit, and you'll likely be much happier with the end result.
Old Jun 27, 2004 | 06:45 PM
SolObsession's Avatar
Spend the money and be happy with the result.
Old Jun 27, 2004 | 07:13 PM
ej1 pilot's Avatar
Default Re: (SolObsession)
sell the OEM for a civic lip...youll probably get more money than you need for a knockoff
Old Jun 27, 2004 | 07:15 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full Intensity &raquo;</TD></TR><TR><TD CLASS="quote">reason being is i threw out my old lip after i replaced the front end from an accident and didn't buy a new one cause i wanted something a lil bigger (the type r one) i can get an aftermarket type r (oem) for 60 bucks i think, to get one made for a civic im looking at 130</TD></TR></TABLE>
link to the aftermarket type r lip?
Old Jun 27, 2004 | 09:18 PM
Teal5GenHatch's Avatar
Get a 00si lip bolts right on i had one or if u buy one ide get the mugen good luck with it
Old Jun 27, 2004 | 09:34 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full Intensity &raquo;</TD></TR><TR><TD CLASS="quote">Will an OEM Integra Type R front lip fit onto a 92 to 95 Civic coup? thx.</TD></TR></TABLE>
Nope, not even close in size/shape. But, if you really want to hack it up and "cut & paste" the lip, then sure you can make it fit but amount & time you put into doing that, it would've been cheaper/easier to just buy an aftermarket front "Type R" lip.
johnsc2235
Jun 10, 2019 07:26 PM
peel17
Nov 17, 2005 08:04 PM
deviusdragger
Mar 2, 2005 06:08 PM
tub_sephiroth
May 9, 2002 12:25 AM
