Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Help with helper springs...
Old Jun 25, 2004 | 03:39 PM
Jaker's Avatar
Default Help with helper springs...
I'm going to use a pair of helper springs on the rear of my car, and wondered if you guys thought it necessary to use some sort of bushing/isolator/locator between the helpers and the main springs? They're the same diameter, and a reasonably tight fit around the shock bodies.
Old Jun 26, 2004 | 04:25 AM
89civicdx's Avatar
Default Re: Help with helper springs... (Jaker)
Use the locator or the main spring will move and might rub up against the shock body/threading. If you don't have a locator then just make something up out tubing(2.5OD ?) just to keep everything centered.
ice11honda
Suspension & Brakes
12
Nov 3, 2005 08:36 PM
NINJASPY
Jan 16, 2004 10:46 AM
