B17A into a 93 Del Sol??
Old Jun 25, 2004 | 03:27 PM
nautica_t's Avatar
Default B17A into a 93 Del Sol??
Is this swap a direct drop? my sister's boyfriend wants to know if this swap will drop right into a del sol using the proper mounts, cuz i know a most b series fit, so i woudln't see why the b17 wouldn't, the b17a will be coming out of a 93 GSR. TIA.
Old Jun 25, 2004 | 03:28 PM
Spade's Avatar
Default Re: B17A into a 93 Del Sol?? (nautica_t)
Only for a DelSol VTEC
Old Jun 25, 2004 | 03:31 PM
nautica_t's Avatar
Default Re: B17A into a 93 Del Sol?? (Spade)
so i'm going to need a mount kit regardless of any b series motor?
Old Jun 25, 2004 | 03:32 PM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nautica_t &raquo;</TD></TR><TR><TD CLASS="quote">so i'm going to need a mount kit regardless of any b series motor?</TD></TR></TABLE>
Yes, a B series is a B series, all the engine block mounting points are the same.
Old Jun 25, 2004 | 03:34 PM
nautica_t's Avatar
damn, i own a EF, is the del sol going to be suffering with 3 mounts as well?
i was looking at hasport.com and they have 2 kits, 1 for cable and 1 for hydro, i don't understand, i thought del sol's only came in hydro's... or is that just for preference for swaps?
btw thanks spade for answering my questions.
Old Jun 25, 2004 | 04:23 PM
AzntaggeR's Avatar
TSPeed Factory
just get as many of the mounts off the b17 as you can. and all the same rules that would apply to swapping it into a 92-95 civic would apply to a del sol. the only exception is you MUST use the shift linkage from a del sol VTEC.
Old Jun 25, 2004 | 08:08 PM
Bill W's Avatar
No, No No...
All of the del sols have mounting points the same as 92-95 Civics (including the 96/97).
The B17 will go in there with the proper transmission/axles/etc... All factory mounts, nothing custom is needed.
mikeljcarr
Feb 13, 2014 08:01 PM
sticest
Apr 26, 2009 03:17 AM
use2bfairladyzguy
Jul 6, 2008 09:33 AM
wdelsolo
Sep 7, 2005 03:52 AM
