ABS HELP!
Old Jun 25, 2004 | 02:47 PM
b-powa's Avatar
Default ABS LIGHT ON HELP!
sup fellas i got a abs light on in my moms car.. need help to check and how to diagnose the problem. plus fix it.
92 accord ex
WHERE CAN U JUMP FOR CODES?
Modified by b-powa at 12:46 AM 6/26/2004
Old Jun 25, 2004 | 03:47 PM
b-powa's Avatar
Default Re: ABS LIGHT ON HELP! (b-powa)
anyone?
Old Jun 25, 2004 | 03:54 PM
.bagged's Avatar
check your ABS fluid reservoir
Old Jun 25, 2004 | 04:05 PM
Schmitey's Avatar
Default Re: ABS LIGHT ON HELP! (bagged93accord)
Could be you have air in the ABS lines. They are two separate systems. Normal brakes can be nice and firm with the posiblilty of having air still in the ABS lines...that could cause a light. Check your sensors on the wheels too, never know what you coulda picked up on the road.
Far as the codes it should be under the glove box, at least it is on my 96 Accord EX. Look for a little blue 2 prong plug connected to a dust cover without any wires. Make sure you got the right plug and ONLY THEN bridge it with a paper clip or something. Turn the ignition and your check engine light should start blinking. Check your manual!
OR...go to an Advanced auto and they'll hook up a scanner for free. Comes in handy with OBD2 (which I doubt you have on a '93).
Old Jun 25, 2004 | 04:54 PM
b-powa's Avatar
Default Re: ABS LIGHT ON HELP! (Schmitey)
anyone else?
i need to know where i can jump for codes... light comes on after a minute of driving,, when i shut off the car and turn it back on it is fine.. after a minute od friving again, it comes back on.. the brakes do lock up when the light is on so abs is not working.
Old Jun 25, 2004 | 10:07 PM
Schmitey's Avatar
what do you mean anyone else? Beggars can't be choosers. I told you dude go to advanced auto and they'll scan the codes if you don't want to do that then suit yourself but don't go crying to the forums.
You got air or something in the ABS where it deactivated itself. Check it out but no-ones gonna fix it for you; you gotta do some detective work.
Old Jun 25, 2004 | 10:24 PM
b-powa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schmitey &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean anyone else? Beggars can't be choosers. I told you dude go to advanced auto and they'll scan the codes if you don't want to do that then suit yourself but don't go crying to the forums.
You got air or something in the ABS where it deactivated itself. Check it out but no-ones gonna fix it for you; you gotta do some detective work.</TD></TR></TABLE>
why would i need to take it to auto zone,, if someone can tell me where to jump the codes. i can go on from there.. u talking about jumping codes from the ecu.. for check engine.. i am not dumb about cars just not with abs.. and i dont need to go to a auto parts store to check codes for engine. that i know how to do. i did a search there is another way u can check abs.. no one says how to.
my expierence with all kraegan and other auto parts store is they dont know ****.. all they can check is a dead batterey. i appreciate u trying to help me but if it is bothering u so much then dont respond.
Old Jun 26, 2004 | 01:34 AM
cd555's Avatar
It appears that you are a victim of a leaky abs unit. Most likely anyway. Schmitey is right you need to jump the wire as if you were going to diagnose the check engine light and pay attention to the abs light instead. See its funny, the same procedure but different lights. That is the way you check abs malfunctions.
Old Jun 26, 2004 | 10:17 AM
b-powa's Avatar
Default Re: ABS LIGHT ON HELP! (farroutt)
^^^ i did ju,p it the cel. light just stay on the abs light made 3 blinks i think it is 30,,, does anyone has a code chart for 30.. or 3.. i am leaning twords 30,,, if it is the same as cel.
Modified by b-powa at 8:00 PM 6/26/2004
Old Jun 26, 2004 | 04:18 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-powa &raquo;</TD></TR><TR><TD CLASS="quote">^^^ i did ju,p it the cel. light just stay on the abs light made 3 blinks i think it is 30,,, does anyone has a code chart for 30.. or 3.. i am leaning twords 30,,, if it is the same as cel.
Three blinks total? Thats probably a code one. Try bleeding the system.
Old Jun 26, 2004 | 09:07 PM
b-powa's Avatar
Default Re: ABS LIGHT ON HELP! (Chiovnidca)
would i have to t bleed it from the abs resivior or brake mc. never done it in a abs.. do u need a special t tool?.. can u explain the process.
Old Jun 26, 2004 | 11:05 PM
david90's Avatar
You need the following:
3/8" clear vynle tubing
clear small bottle
10mm wrench
1 quart of brake fluid
0. Refill your abs unit with honda brake fluid
1. Install the clear tubing on the bleeder bolt and dip the other end into a clear bottle with brake fluid.
2. start your engine
3. open the bleeder bolt and close as soon as the fluid comes out is clear with no air bubble. It comes out fast so opening and closing the bleeder bolt must be done fast to avoid emptying the reservior. The res. capacity is around 300ml so opening the bleeder bolt a sec too long will empty the res. and introduce air into the system.
4. After the bleeder bolt is close, shut off engine and refill the res. to max.
Old Jun 27, 2004 | 01:07 AM
blueludedude's Avatar
probably a wheel sensor
Old Jun 27, 2004 | 12:22 PM
16.45_stock_94accord's Avatar
here is a test for u to do.. jack the car up by the front... let it outta get and get the tires to spin. if the abs light comes on its one of ur front 2 wheel sensors. if it doesnt come on try the same with the back wheels but u have to keep the car in park and manually move the back wheels one at a time. i just had the same problem and i found it was my right rear wheel that way.. good luck and tell me what u find.
Old Jun 27, 2004 | 08:46 PM
b-powa's Avatar
Default Re: ABS LIGHT ON HELP! (16.45_stock_94accord)
i'll try thanks guys
Old Jul 20, 2004 | 07:02 AM
brianlmoon's Avatar
I have the same problem with my 93 EX. Interestingly, it does not come on while in reverse. Also, it does not come on until I start moving forward at more than idle speeds. Kinda sounds like a wheel sensor, but don't know. I just recently got new front breaks. It started coming on just before that. Does that mean anything to anyone before I start with the other tests mentioned above?
Old Jul 20, 2004 | 09:18 AM
RotaryBzzzz's Avatar
Default Re: ABS LIGHT ON HELP! (brianlmoon)
lots of ABS info in my sig
Old Jul 20, 2004 | 01:55 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brianlmoon &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem with my 93 EX. Interestingly, it does not come on while in reverse. Also, it does not come on until I start moving forward at more than idle speeds. Kinda sounds like a wheel sensor, but don't know. I just recently got new front breaks. It started coming on just before that. Does that mean anything to anyone before I start with the other tests mentioned above? </TD></TR></TABLE>
What trouble code does it have stored?
kit50si
Nov 21, 2007 01:24 PM
superman422
Aug 15, 2006 11:28 AM
jfish73
Jul 4, 2005 10:24 AM
redteg1
Aug 18, 2001 02:42 PM
