sir or gsr head with CTR pistons????
Old Jun 25, 2004 | 02:05 PM
EG_Type R's Avatar
Default sir or gsr head with CTR pistons????
I have a b18c1 motor, but I also have a b16 head. I was wondering which head would run better, stronger, and safer in a b18 block with ctr pistons??
Old Jun 25, 2004 | 02:39 PM
Dancing is Forbidden's Avatar
Default Re: sir or gsr head with CTR pistons???? (blue_b18)
The B16a is a better head for Intake manifold purposes. You can bolt on an ITR IM and call it a day. The B18c head will outflow the B16a head up top just a little bit more. Id stay with the b18c head and get a Skunk2 IM.
Old Jun 25, 2004 | 02:44 PM
DefiantGSR's Avatar
Default Re: sir or gsr head with CTR pistons???? (lsvt3c)
if both heads are off, go with the b16 head. it flows a little better between lifts .25 - .45. what octane is available to you? if its 91 octane, the b16 head will lower compression a bit to be more friendly. What cams are you going to run? This will determine what compression you need.
Old Jun 25, 2004 | 03:23 PM
EG_Type R's Avatar
Default Re: sir or gsr head with CTR pistons???? (DefiantGSR)
I forgot to mention that I have an Skunk 2 im, and my throtle body is bored out. Im not sure what cams to use? what cams in what head? suggestions?
DSR!
Oct 22, 2004 07:43 AM
KB96VTEC
Dec 25, 2003 07:00 PM
Lucifer6i9
Nov 9, 2003 11:05 PM
crxste
Aug 19, 2003 08:16 PM
RJL
Dec 22, 2001 08:54 PM
