think this jensen amp does 100x4 rms?
Old Jun 25, 2004 | 02:00 PM
bassisliffe's Avatar
Default think this jensen amp does 100x4 rms?
it feels heavy
and uses 2 25 fuses!
just wanna know if you think it does the rated power? ima use it on some mids for a while just got it used
Old Jun 25, 2004 | 02:34 PM
debogsr's Avatar
Default Re: think this jensen amp does 100x4 rms? (bassisliffe)
no, its heavy cuz its metal. They sell Jenson at target and sears. Quality?
Old Jun 25, 2004 | 07:10 PM
fcm's Avatar
fcm
Old Fart
NO!
Old Jun 25, 2004 | 07:22 PM
Default Re: think this jensen amp does 100x4 rms? (fcm)
but it uses 2 25 amp fuses
Old Jun 25, 2004 | 07:47 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">but it uses 2 25 amp fuses </TD></TR></TABLE>
Maby 100 watts total for 1 nano sec. at 1500Hz all ch. driven into 1ohm with 14.9 volts and 5.5 THD. or not 94
Old Jun 25, 2004 | 07:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
Maby 100 watts total for 1 nano sec. at 1500Hz all ch. driven into 1ohm with 14.9 volts and 5.5 THD. or not 94</TD></TR></TABLE>
i hate you!
ok so i guess this will be my tweeter amp
Old Jun 25, 2004 | 08:25 PM
parasonic's Avatar
...if you want distorted highs.
Old Jun 25, 2004 | 08:26 PM
jlc-bigj's Avatar
If you use that amp, make sure you hide it behind a panel or something so nobody sees it. We can debate JL vs. RF all day, but I thought everyone knew to stay away from Jensen.
Old Jun 25, 2004 | 11:56 PM
STEV3-O's Avatar
Default Re: think this jensen amp does 100x4 rms? (jlc-bigj)
get the Infinity 7540a 4-channel amp. I just got my in, just waiting on my kappa perfect components to see how it performs, cant got wrong with 111x4 at 4 ohm's rms power for 150 bucks
Old Jun 26, 2004 | 04:00 AM
Default Re: think this jensen amp does 100x4 rms? (parasonic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by parasonic &raquo;</TD></TR><TR><TD CLASS="quote">...if you want distorted highs.</TD></TR></TABLE>
my pioneer premeirs arent distorting on it, i have a coustic xm-6 that helps alot though, as i said this will be my tweeter amp, ill just use my 500a2 punch for mids
Old Jun 26, 2004 | 08:01 AM
john666's Avatar
that amp looks like it came back from the dead.. let it die in peace.. or sell it
Old Jun 26, 2004 | 08:40 AM
Default Re: think this jensen amp does 100x4 rms? (john666)
sell it? you mean give it away
Old Jun 26, 2004 | 09:03 AM
turbosi03's Avatar
yeah for a tweeter amp if should be fine (I guess) because high freq. doesnt require nearly as much power... so you can adust the gain low enough to not cause distortion.
I hate those amps every one I tried to use sounded like **** and have poor x-overs...
good luck...
Old Jun 26, 2004 | 01:30 PM
Default Re: think this jensen amp does 100x4 rms? (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">yeah for a tweeter amp if should be fine (I guess) because high freq. doesnt require nearly as much power... so you can adust the gain low enough to not cause distortion.
good luck...</TD></TR></TABLE>
poor x-over? you mean NO x-over
Old Jun 26, 2004 | 03:50 PM
specv5150's Avatar
Default Re: think this jensen amp does 100x4 rms? (debogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">no, its heavy cuz its metal. They sell Jenson at target and sears. Quality?</TD></TR></TABLE>
Wal-Mart too......
I would MAYBE expect it to maybe do 100x4 PEAK not RMS. So basically you would get power at a similar quality to a cheap head deck
yesSiReK
Oct 19, 2006 09:40 AM
bassisliffe
Audio / Security / Video
Mar 18, 2005 04:17 AM
bassisliffe
39
Jun 30, 2004 07:53 AM
jordan-boxer
15
May 8, 2004 06:03 PM
SargentNg
25
Apr 22, 2003 08:14 PM
