What company makes LCA's for CRX's?
Old Jun 25, 2004 | 05:50 AM
bayareatuners's Avatar
Default What company makes LCA's for CRX's?
Just like the title says.
Old Jun 25, 2004 | 06:53 AM
APEX CRX's Avatar
Default Re: What company makes LCA's for CRX's? (EF8 All Motor)
SPC and Function 7
Old Jun 25, 2004 | 08:39 AM
MikeySpec's Avatar
Default Re: What company makes LCA's for CRX's? (APEX CRX)
Im running ITR lca's on my crx...great setup
Old Jun 25, 2004 | 08:46 AM
AgentJam's Avatar
Default Re: What company makes LCA's for CRX's? (MikeySpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeySpec &raquo;</TD></TR><TR><TD CLASS="quote">Im running ITR lca's on my crx...great setup</TD></TR></TABLE>
What is better about the ITR lower arms?
Vince
Old Jun 25, 2004 | 10:07 AM
HatchBox's Avatar
Skoobie no more...
Default Re: What company makes LCA's for CRX's? (AgentJam)
you can run alot more suspension set ups that way. where as with the crx LCA's your limmited to what kind of suspension set up you want.
Old Jun 25, 2004 | 10:24 AM
EL Vap133's Avatar
Default Re: What company makes LCA's for CRX's? (Hybrid Hatchback)
Bleh, I got rid of my 88 lcas.
Old Jun 25, 2004 | 10:56 AM
MikeySpec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">
Vince</TD></TR></TABLE>
I lucked out on a great set with new solid bushings. They're lighter for sure and there was some scientific geometry crap that someone tried to explain to me...but i fell asleep listening. I went from tein basics to omni powers the ones i have are for a type r. So im running eg shock forks and the itr lca's. The car performed alot better at the track.....
Old Jun 25, 2004 | 11:02 AM
Davep's Avatar
Anybody running the SPC arms or the SRR arms?
Old Jun 25, 2004 | 01:00 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeySpec &raquo;</TD></TR><TR><TD CLASS="quote">I lucked out on a great set with new solid bushings. They're lighter for sure and there was some scientific geometry crap that someone tried to explain to me...but i fell asleep listening. I went from tein basics to omni powers the ones i have are for a type r. So im running eg shock forks and the itr lca's. The car performed alot better at the track..... </TD></TR></TABLE>
I know I asked about the ITR LCA's before being a direct bolt-in to 88's, but can you use the 88 CRX shocks or do you have to use the ITR shocks. I heard ITR arms are slightly wider to allow for a beefier shock. Maybe some washers could help the problem. jw
Old Jun 25, 2004 | 01:02 PM
crx_88_si's Avatar
Default Re: What company makes LCA's for CRX's? (88 rex)
they're also 1/16" longer.
Old Jun 25, 2004 | 01:52 PM
88 rex's Avatar
Default Re: What company makes LCA's for CRX's? (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">they're also 1/16" longer.</TD></TR></TABLE>
I beleive someone has a pic on here with the two of them side by side and they "appeared" to be identical length..........Either way, camber kit will fix that little bit.
Old Jun 25, 2004 | 04:56 PM
AgentJam's Avatar
hmm interesting so what year ITR...any? Are you guys rocking them just up front or all around?
Vince
Old Jun 25, 2004 | 05:45 PM
XrcR6's Avatar
Should be any year DC2-R rear LCA.
I believe all the comments in this thread, while they didn't specify, pertain only to rear LCA's. Honestly haven't seen any aftermarket front LCA's made yet, outside of a couple one-off custom ones (and Competition Engs. drag setup for EG-DC). Also EG-DC front LCAs are a different design than ED-EF so no swap over of OEM parts is going to happen.
Old Jun 25, 2004 | 05:51 PM
Karterguy13's Avatar
Default Re: What company makes LCA's for CRX's? (XrcR6)
can you guys poast some URl's for this kind of stuff? please. THANKS
Old Jun 25, 2004 | 05:57 PM
Default Re: What company makes LCA's for CRX's? (Karterguy13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karterguy13 &raquo;</TD></TR><TR><TD CLASS="quote">can you guys poast some URl's for this kind of stuff? please. THANKS</TD></TR></TABLE>
You read my mind, I was going ask the samething.
Old Jun 25, 2004 | 06:06 PM
deftones0817's Avatar
competition engineering makes some cool front lower control arms...but they arent street legal.
DEF
Old Jun 25, 2004 | 11:48 PM
MikeySpec's Avatar
Default Re: What company makes LCA's for CRX's? (deftones0817)
My itr lca's are out of a japanese 98 coupe. They are identical size to the stockers. And as far as the width for the shock....i believe the itr shock is a little wider. You can use washers.
Old Jun 26, 2004 | 05:02 AM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeySpec &raquo;</TD></TR><TR><TD CLASS="quote">My itr lca's are out of a japanese 98 coupe. They are identical size to the stockers. And as far as the width for the shock....i believe the itr shock is a little wider. You can use washers.</TD></TR></TABLE>
Thanks
bacardiboi
Jul 24, 2007 06:58 PM
96lude_srv
Mar 1, 2007 08:34 AM
FuKThEiVeS
Nov 4, 2006 06:31 PM
vega_ROCKS
Suspension & Brakes
Jun 23, 2006 01:38 PM
allmotaR
Aug 12, 2005 08:20 AM
