Track tire pressure?
Ok i was just wondering about tire pressure at the track. Im running 14x6 miata wheels with 195/55/14 azenis
Tire pressure that i would like is
front 17-19 psi
rear 40 psi
are these settings off? would you suggest a different setting?
front 17-19 psi
rear 40 psi
depending on how many runs you plan on doing start higher and gradually drop the pressure down, cuz you can loose pressure some during racing and then your tires could be too flat for proper traction.
when i ran my 14.0 flat runs i wasnt getting good traction at 24psi. then when i hit my 13.7 run i had decent traction and it was at 22 psi. so i figured a nice launch on 19 would just grab. hopefully i can cut something better than a 2.2 60'
Heinz57
Oct 14, 2003 09:37 PM
