front brakes tomorrow, any pointers?
Old Jun 24, 2004 | 10:27 PM
hatchback_al's Avatar
Default front brakes tomorrow, any pointers?
Hey guys, i just got a set of front pads for my 91 civic dx hatch because my current pads are quite worn. The steering wheel tends to wobble from time to time at high speeds and when i press on the brakes, i hope the new pads will help this. Anyways, Ive never done them on my civic, anything good to know ahead of time? Should i get new rotors also? thanks
Old Jun 24, 2004 | 11:19 PM
DXDOHCVTEC's Avatar
being that the brakes "wobble" it is probably due to warped rotors so the new pads may not take that away.
Old Jun 24, 2004 | 11:32 PM
XrcR6's Avatar
Default Re: front brakes tomorrow, any pointers? (hatchback_al)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al &raquo;</TD></TR><TR><TD CLASS="quote">...The steering wheel tends to wobble from time to time at high speeds and when i press on the brakes...</TD></TR></TABLE>
Like suggested, warped rotors would cause the vibration/wobble under braking. Some new rotors would address this.
If its doing that just driving at high speeds (off the brakes) there's something else you need to look at though... Could be time to re-balance the rim/tire assembly. Or if your using aftermarket rims that need hubcentric rings (but aren't), could be that the wheel is mounted off-center slightly. Could be other things too, but try those first.
Old Jun 25, 2004 | 09:06 AM
Default Re: front brakes tomorrow, any pointers? (XrcR6)
ok i just had my wheels balanced so its not that, they are just crx si wheels not aftermarket. any pointers on getting the brakes done?
Old Jun 25, 2004 | 11:20 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XrcR6 &raquo;</TD></TR><TR><TD CLASS="quote">
turn the rotors or replace them
Old Jun 25, 2004 | 11:22 AM
EL Vap133's Avatar
Default Re: front brakes tomorrow, any pointers? (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">
turn the rotors or replace them</TD></TR></TABLE>
YUp, if not you will feel the same wobble.
Old Jun 25, 2004 | 01:01 PM
crx_88_si's Avatar
Default Re: front brakes tomorrow, any pointers? (EL Vap133)
you need new rotors.
Old Jun 25, 2004 | 04:29 PM
XrcR6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al &raquo;</TD></TR><TR><TD CLASS="quote">ok i just had my wheels balanced so its not that, they are just crx si wheels not aftermarket. any pointers on getting the brakes done?</TD></TR></TABLE>
You probably already started by now, but:
1) An impact driver to remove the two phillips-head screws in each rotor. Or else you will strip the heads trying to use a regular screwdriver.
2) A big enough channel-lock, pliers or c-clamp to compress the piston back in the caliper. Or you may not be able to put the caliper back in place with the new pads.
3) A friend to help you bleed the brakes.
4) A container of some sort to collect the old brake fluid.
5) Some tubing (about aquarium size) from the hardware store to connect between the bleeder and the container.
6) Brake cleaner, latex gloves, wire brush, rags, tools, etc. etc. etc.
EK9 BEEZLER
Jul 25, 2005 04:44 AM
Rydaddy
15
Mar 11, 2004 04:33 AM
knowtomorrow3001
Jan 15, 2004 08:56 AM
TypeRuz
Nov 16, 2003 09:42 AM
BrandonClaps
Sep 4, 2002 11:24 PM
