oem front end question for crx techs
Old Nov 17, 2001 | 03:05 AM
REXcellent's Avatar
New User
Default oem front end question for crx techs
just wondering if the 90 or 91 oem crx si front bumper will fit the 88 crx si ? same with the tail lights.. thanks
Old Nov 17, 2001 | 08:20 AM
stockcrix1616's Avatar
Default Re: oem front end question for crx techs (REXcellent)
actually it fits, but dosent look right, the 90-91 has different turn lights and different side lights, like it said it will fit but the gap between the hood and bumper is a lil larger, but you can get away with it, and the tail lights, yes they will bolt right in, the onlt difference is one has a black strip around then and the others are all tail light, basicaly just makes one look larger then the other, the 90-91 is the one with the strip, the 88-89 have the larger looking lights, hope this helps
Old Nov 17, 2001 | 04:32 PM
glagola1's Avatar
I've had both of these years and the bumper cover is actually very simlilar between years but the support is different. If you use the support from the 88 with the 90 cover things will work fine except that the black strip that runs around the car is thinner on the later version and fatter on the earlier car so it might look a little off.
Bottom line, it will work if you are patient and creative. Good luck.
OddityDX
Sep 15, 2009 10:21 AM
gcturismo
60
Jun 5, 2008 01:59 PM
project_hf
Aug 6, 2006 12:15 PM
imptricer
15
Apr 23, 2006 09:42 AM
