Problem with distributor
Old Jun 24, 2004 | 07:07 PM
TJSUPE's Avatar
Default Problem with distributor
I did a search and found nothing I have a 91 crx dx i have replaced the distributor cap rotor and coil pack. It ran fine for awhile (it isn't my daily driver) so about 50 miles of intermittant use over the course of about a month. then i took it out today and when I got home there was a terrible noise coming from the distributor like something was loose in it and the rotor was bouncint it around. I took the cap off and tightened the rotor and coil pack looked for anything that looked loose found nothing. put the cap back on and it did not help any suggestions
Old Jun 26, 2004 | 05:45 AM
TJSUPE's Avatar
Default Re: Problem with distributor (TJSUPE)
Any help? or suggestions
Old Jun 26, 2004 | 06:09 AM
MENACE's Avatar
The Bearing is bad. Your gonna need to buy a New Distributor. If you wanna make sure check for play on the Shaft and look for red dust in the cap both sure signs.
Old Jun 26, 2004 | 10:03 AM
EFSiR's Avatar
Default Re: Problem with distributor (MENACE)
menace is right. you also need new cap a rotor. arrrrh fudge nuts ehhhh?
Old Jun 26, 2004 | 11:48 AM
TJSUPE's Avatar
Default Re: Problem with distributor (EFSiR)
Thanks guys appreciate the help
yangkm
Feb 26, 2011 04:20 PM
BoombasticSloth
Jun 21, 2008 03:39 PM
GRM Scott
Mar 1, 2002 04:41 PM
