I think I'm screwed...any kind of permanent fix?
Old Nov 16, 2001 | 11:52 PM
turbocoupe's Avatar
Default I think I'm screwed...any kind of permanent fix?
O.K. my buddy was helping me install my door poppers this past weekend...but it didn't work out long story. Anyhow, he put the brain to the system under my brake and clutch, not directly under but a little further up. So, the door popper kit is the wrong one so I take the brain out. I turn on the car and all you hear is a vaccum leak. My buddy Aaron and I are looking in the engine for loose hoses...everything is in it's place. Then Aaron realizes where the screw to the brain was has punctured the "area" where all the vaccum is created. . .so I just put the screw back in. Today I was driving and I could hear it.. . .now I'm not boosting like I was! Any ideas how to fix this. . .or how much to replace?
Thanks,
Marc
Old Nov 16, 2001 | 11:54 PM
dustin's Avatar
Default Re: I think I'm screwed...any kind of permanent fix? (turbocoupe)
Where did you screw the brain to again?
dustin's Avatar
Default Re: I think I'm screwed...any kind of permanent fix? (dustin)
Btw I like your sig, smashing pumpkins own
Old Nov 17, 2001 | 12:05 AM
turbocoupe's Avatar
Your the first one to know it's SP. . .
O.K. the brain was about 6" long. If I pressed the clutch all the way down I would hit it. He put it on the firewall inside the car.
Old Nov 17, 2001 | 12:08 AM
dustin's Avatar
to lie here and die, among the sorrows adrift among the days......
Hrm, so you screwed THROUGH the firewall?
Dustin
Old Nov 17, 2001 | 12:22 AM
turbocoupe's Avatar
you got IM.
Old Nov 17, 2001 | 03:04 PM
turbocoupe's Avatar
ttt
Old Nov 18, 2001 | 09:07 PM
Giuseppe's Avatar
did u punctured the brake booster!!??
Old Nov 18, 2001 | 11:11 PM
turbocoupe's Avatar
Default Re: I think I'm screwed...any kind of permanent fix? (Giuseppe)
Possibly, when I push the pedal is goes down alot further than it did before...
Old Nov 18, 2001 | 11:50 PM
dbman96's Avatar
New User
I think we have a winner... sounds like someone's going to have to pull off that brake booster at the very least and see if it can be patched up - otherwise get a replacement brake booster.
If you REALLY want to be a cheapass you could just try sticking a wad of epoxy putty over the hole and see if it seals up OK.
Old Nov 19, 2001 | 12:03 AM
turbocoupe's Avatar
Default Re: I think I'm screwed...any kind of permanent fix? (dbman96)
Gee I've never won anything before! anyway I can hear a vaccum leak somewheres. . .when I push the brake pedal in, it goes away. . .oh well we shall see...
Old Nov 19, 2001 | 08:58 AM
92sleepR's Avatar
New User
You definitely punctured the brake booster. Take it off and patch it with a little JB Weld. You will be fine.
Mike
Old Nov 19, 2001 | 02:54 PM
turbocoupe's Avatar
Default Re: I think I'm screwed...any kind of permanent fix? (92sleepR)
will do! Thanks everyone!
Marc
Old Nov 19, 2001 | 08:12 PM
Giuseppe's Avatar
JB weld will only patch up the metal housing!
ive never opened one up but, im assuming that
internally, there has to be a diaphragm of some sort
which is obviously punctured too,... JB weld wouldnt fix this one..
so i suggest you take it off and replace the thing,
you dont want it getting worse.!!!
HTH
[Modified by Giuseppe, 5:14 AM 11/20/2001]
Old Nov 19, 2001 | 08:25 PM
FULLTHROTTLE's Avatar
It should be ok just to patch the housing, if You punctured the bladder inside, your brake pedal would feel like there was a brick under it. Make sure you sand the paint away from the area you patch. It wont stick very well to the painted surface.
Oh, and nice job by the way.
Old Nov 19, 2001 | 08:29 PM
turbocoupe's Avatar
Default Re: I think I'm screwed...any kind of permanent fix? (FULLTHROTTLE)
Thanks! I already ripped by buddies head off for it.
scartail
Sep 16, 2009 05:00 AM
young_tuner
15
Aug 5, 2009 12:52 PM
prakthad
Feb 13, 2008 04:21 PM
AspectIndustries
Apr 17, 2005 12:38 AM
4drEF
13
Jan 13, 2004 08:18 AM
