Getting ready to order a B18C1 for my friends 96 civic, should I get a OBD I or OBD II engine?
Getting ready to order a B18C1 for my friends 96 civic, and I was wondering if should I get a OBD I engine and use the stock harness and run a jumper wih a p72 ecu or should I get OBD II engine and run the civic or integra harness with the OBD II GSR ECU? Also which mounts work best I don't quite know, I have done a few EG motor swaps but his is my first EK swap.
Thanks
Thanks
you can make an OBDI ECU work with the OBDII GSR swap.....holler at Newman for a jumper harness.
clean-jdm-ek
Aug 24, 2005 12:33 AM
The Mole
Jan 12, 2003 04:54 PM
