? Sticky gas pedal and wierd noise when turning?
OK I have a 99 accord ex and if i press the gas pedal lightly it wont gas, I have to press it down pretty hard like im passing a detent or something, any ideas of the problem?
Plus every time I turn the steering wheel all the way in one direction it makes this wierd noise like buzzing, I know its not the tire rubbing I heard it can be the power steering. Thanks for any help
for the pedal, it sounds to me like your throttle cable needs to be tightened up...it's extremely easy to do, just tighten it on the throttle body...
as for the power steering pump, you may be low on fluid or the fluid you do have may need replaced...check it and find out...
I would first check the throttle cable and p/s fluid first
If it persists I would then look into other things such as filters, plugs, wires etc to start.
the newer 4cylinder got a recall(mostly 01-02 SE with f23a4) for the sticky thottle plate, might as well check it out
is it only in the morning?
do you think is the panel is jamming or the tb rotor?
CheezeFrog
Nov 18, 2019 11:11 PM
Inextricabledrvr
Mar 18, 2009 07:56 PM
, not sure about the pedal though
