which headgasket for b18c R all motor?
Old Nov 16, 2001 | 07:35 PM
infinkc's Avatar
Default which headgasket for b18c R all motor?
wanting to get a spoon or mugen headgasket to raise my compression what thickness is best to get? thanks and is there any shops in so cal i can get one cheap?
Old Nov 16, 2001 | 08:54 PM
Mike K's Avatar
Default Re: which headgasket for b18c R all motor? (infinkc)
dont bother with a mugen or spoon one. too expensive.
better solution:
buy a b18c headgasket(12251-P30-014) $60.00 or so
buy a can of permatex spray-a-gasket, the red stuff or the copper
find a friend with a dremel or a drill press
get rid of the rivets on the stock gasket.. then decide which layer you wanna use. i would use the bottom one. then spray both sides with the spray gasket and put the head on. good to go.
outer black layers are 12 thousandths each, inner is 8 or 9 thousandths.. so do the math and you can find out how much increase you'll get in compression.
Old Nov 16, 2001 | 09:41 PM
AJ PwR's Avatar
Spoon and Mugen are all made by Honda so quality will be way higher then stock head gasket. Spoon's head gasket is a 2 layer laser welded head gasket, it provides more engine stability during hi-rpm ranges.
Old Dec 19, 2009 | 05:51 PM
BradleyJP's Avatar
better solution:
First I've heard of this method. I assume you've done this with success?
yoorang
16
Nov 12, 2006 04:51 PM
ricearoni56
Nov 12, 2004 08:20 AM
bubbajim
Aug 21, 2003 07:26 PM
snake01
Nov 13, 2002 03:26 PM
RTW DC2R
May 24, 2002 06:52 AM
