Took the Denso iridium plugs out and put copper NGK plug in..
I finally decided to pull the denso iridium plugs out of my wife's accord after about 5 months of using it. It was giving me really bad gas mileage, really bad idle and worse throttle response. At one point, I almost thought it was because the engine is getting old (60k miles). I finally took the plugs out last week and replaced it with NGK V-power copper plugs. The bad idle is gone, the bad throttle response is gone. It even shifts smoother now (auto tranny), no more jerking at low speed shifting.
I still need to check the gas mileage later on and make sure the plugs is what cause the low gas mileage problem.
If anyone has similar experience with iridium plugs, I would recommand swapping them out right away.
