turbo prelude SH ???
Old Jun 24, 2004 | 07:56 AM
idragbodys10's Avatar
Default turbo prelude SH ???
i am looking to turbo my 98' prelude SH...not sure what to do (about the ATTS)??.....please help
Old Jun 24, 2004 | 07:59 AM
98TypeSH's Avatar
Default Re: turbo prelude SH ??? (idragbodys10)
I recall posting quite a few times about this, anyways here we go.
The ATTS usally craps out right around 250 HP, making it usless dead weight. The only REAL way to get rid of the atts, is to pull the unit and do a tranny swap. You could leave it in, but it will take a big turd, and in the event you swap ECU's youll lose it right there as well. Everyone says get a base and blah blah, just swap for a JDM h22 tranny and away you go. As i recall you might need to fabricate a few additional peices to get it in. Good luck.
Old Jun 24, 2004 | 11:37 AM
PetroGuyX's Avatar
just don't make 250 whp
Old Jun 24, 2004 | 11:55 AM
spoolinlude's Avatar
I live under a rock
Default Re: (PetroGuyX)
sure do, you need to make a lil bracket and tweak some ****.....
My buddy did it...... search for clendaniel, then go to his personal webpage, its somewhere in there
Old Jun 24, 2004 | 07:53 PM
^i e-mailed him..thanks
Old Jun 24, 2004 | 08:26 PM
clendaniel's Avatar
You've got a couple options...keep the ATTS unit w/ a piggyback setup (hack, emanage, fmu, etc), disable the unit and run a standalone, or swap out for a base-style tranny and run whatever you want. I swapped mine out for a quaife-equipped h23 trans...you can see the basics of the mods necessary here: http://ian.clendaniel.net/gallery/noatts I wouldn't worry about this, though, until you're running into issues with it. There's no use throwing parts at the car that you don't need, get the bugs worked out of the f/i setup first...once it starts kicking off and having problems then take care of it.
--Ian
Old Jun 24, 2004 | 08:40 PM
preludedriver99
Guest
Posts: n/a
Default Re: turbo prelude SH ??? (clendaniel)
I'm going to be running into the same problem real soon since my block and head are both being fully built. Just pull the atts fuse if your going to be running boost. Leave it the way it is and it will drive just like a base. It weighs about 83 lbs, I've got my atts off the block right now and just weighed it. That doesn't even equal a tenth of a second in the 1/4 mile. Problem solved!
rive22's Avatar
just tune your stuff at like 235 whp. you'll be straight. then you can keep the atts for superb handling. i forgot what the stock whp (not crank) is for the 5G lude, but i would guess it's like 160-165 or something. that leaves you some good room for some boost.
Old Jun 24, 2004 | 08:43 PM
Kal's Avatar
Kal
Default Re: (rive22)
It's not like 235whp going through the ATTS system will keep it running superbly.. 235whp is a lot of power...meant for turning quickly.
Old Jun 24, 2004 | 08:45 PM
clendaniel how many hp does ur car put out?
Old Jun 24, 2004 | 08:46 PM
Kal's Avatar
Kal
Considering you're planning to boost... I suggest you dump the ATTS and get a standalone system, e.g. - Hondata, AEM EMS...
They will give you the tuning capability to keep your motor from blowing up and getting maximum power lol.
Old Jun 24, 2004 | 08:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clendaniel &raquo;</TD></TR><TR><TD CLASS="quote">You've got a couple options...keep the ATTS unit w/ a piggyback setup (hack, emanage, fmu, etc), disable the unit and run a standalone, or swap out for a base-style tranny and run whatever you want. I swapped mine out for a quaife-equipped h23 trans...you can see the basics of the mods necessary here: http://ian.clendaniel.net/gallery/noatts I wouldn't worry about this, though, until you're running into issues with it. There's no use throwing parts at the car that you don't need, get the bugs worked out of the f/i setup first...once it starts kicking off and having problems then take care of it.
--Ian
what is the best to do in the long run?
Old Jun 24, 2004 | 08:54 PM
Default Re: turbo prelude SH ??? (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">Considering you're planning to boost... I suggest you dump the ATTS and get a standalone system, e.g. - Hondata, AEM EMS...
if u get different ECU (Hondata, AEM EMS...) and unhook the ATTS...you could run a turbo w/o having to buy a new tranny ?
is that all u would have to do (is it a good thing to do)??
Old Jun 24, 2004 | 10:22 PM
preludedriver99
Guest
Posts: n/a
Pull the fuse and it will drive like a base only it will be a bit heavier. 82-85 lbs isn't that big of deal in the 1/4 mile department, about a tenth of a second if that, whoopy just pull the fuse if your going to boost above 6 to 8psi!
Old Jun 25, 2004 | 07:10 AM
Default Re: turbo prelude SH ??? (preludedriver99)
i'm a newbie and just still a little unclear about what is the best thing to do.....don't wanna mess my car up by doing something wrong
Old Jun 25, 2004 | 06:40 PM
clendaniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idragbodys10 &raquo;</TD></TR><TR><TD CLASS="quote">
what is the best to do in the long run?</TD></TR></TABLE>
It depends...if you're planning on keeping car and want to get the most out of it then the tranny swap with an LSD is the best IMHO.
--Ian
Old Jun 25, 2004 | 06:43 PM
clendaniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriver99 &raquo;</TD></TR><TR><TD CLASS="quote">Pull the fuse and it will drive like a base only it will be a bit heavier. 82-85 lbs isn't that big of deal in the 1/4 mile department, about a tenth of a second if that, whoopy just pull the fuse if your going to boost above 6 to 8psi!</TD></TR></TABLE>
Pulling the fuse only acts like an open diff, though...if you're making too much power for the ATTS unit chances are you'd _really_ benefit from the addition of a LSD.
--Ian
Old Jun 25, 2004 | 08:59 PM
Kal's Avatar
Kal
No LSD fits into the ATTS tranny block.
Old Jun 26, 2004 | 09:07 AM
clendaniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">No LSD fits into the ATTS tranny block.</TD></TR></TABLE>
WTF are you talking about? If you'd read the rest of the thread you would see that I have a base transmission on my SH block which easily fit a quaife. His question was whether it was better to swap off the ATTS tranny for a base one. I was simply stating that if he was making the power necessary to have to get rid of ATTS that he'd likely benefit from an LSD instead of "pulling the fuse" as suggested in another post.
--Ian
Old Jun 26, 2004 | 09:08 AM
Kal's Avatar
Kal
i meant the ATTS tranny. not the engine block
Old Jun 26, 2004 | 09:24 AM
clendaniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">i meant the ATTS tranny. not the engine block </TD></TR></TABLE>
Saw that as soon as I posted and edited accordingly...
--Ian
Old Jun 27, 2004 | 07:38 AM
--Ian
LSD?
Old Jun 27, 2004 | 07:53 AM
what's the best tranny swap? (base h22 tranny....h23 tranny?) where is the best place to find one?
Old Jun 28, 2004 | 06:19 AM
