Antenna doesnt work at all, but isnt broken
Old Jun 23, 2004 | 11:30 PM
Hasboro's Avatar
Default Antenna doesnt work at all, but isnt broken
My power antenna doesnt go up or work at all even when the stereo is plugged in, ive tried several stereos so its not the stereo, and it worked for a split second when I was installing a deck after not working, but then it just stopped working, and hasnt been working since. I dont get any radio signal thru my deck either. What could be the problem? I have tried 3 different decks and its definately not the motor, etc on the antenna because it has worked once, but i have no clue why it started working and stopped again.
Old Jun 23, 2004 | 11:38 PM
teg01ls's Avatar
Default Re: Antenna doesnt work at all, but isnt broken (Hasboro)
Get an s2k antenna
Old Jun 23, 2004 | 11:49 PM
Cheminova's Avatar
Default Re: Antenna doesnt work at all, but isnt broken (teg01ls)
I think he means that the antenna isnt getting a signal from the radio for some reason, and so the antenna just isnt doing anything for amplifying the signal
Old Jun 24, 2004 | 10:36 AM
roadrunner's Avatar
On the multi connector on the back of the head unit, check the condition of the appropriate wire and connector that sends the trigger signal to the antenna's motor. They sometimes get gunked with grime and dust and won't conduct. Cleaning them will usually fix the problem...
Old Jun 24, 2004 | 02:17 PM
crawdad689's Avatar
Default Re: (roadrunner)
stock antenna doesn't work?
join the club.......
s2K antenna...
Old Jun 24, 2004 | 02:25 PM
SMZ GSR's Avatar
Default Re: (crawdad689)
the cable inside the antenna probably broke, fairly common. What worth it to fix IMO. I'm happy with my S2K antenna, but i don't suggest the cheaper $20-30 kits... get the full setup straight from honda (about $115). Much better quality and better signal strength.
V-Thang
Jul 23, 2004 09:45 PM
TSAngry
Feb 26, 2004 01:16 PM
geminis2k
Jan 30, 2004 09:10 AM
geminis2k
Dec 1, 2003 10:53 PM
pm41
Audio / Security / Video
Sep 22, 2003 11:47 PM
