Has anyone ever solved the infamous clutch pedal click?
Old Nov 16, 2001 | 06:19 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Has anyone ever solved the infamous clutch pedal click?
Did a serch, and it seems as if no one has ever found a answer to this problem. I step on the clutch and right before it's all the way to the floor "CLICK" you can even feel it on your foot. A friend has a 2001 ITR and his makes no noise what so ever, and for some reason it's smoother. How can I explain it? It takes less force to press the pedal to the floor. I wonder if this is related to my clicking problem. If you've solve this problem, or have an ideal on what could be causing it, please respond to this post. Thank you in advance.
Old Nov 16, 2001 | 06:55 PM
yellow blur's Avatar
Default Re: Has anyone ever solved the infamous clutch pedal click? (01PYTypeR#1140)
dealer checked out mine 2 times, they eventually ended up replacing the master clutch cylinder, and shaving a piece down on the fork or something or other. then again your car is modded the hell out. my work was done under warranty. good luck.
Old Nov 16, 2001 | 06:59 PM
Driver's Avatar
Default Re: Has anyone ever solved the infamous clutch pedal click? (yellow blur)
I have the same problem and mine is a "stock" 2001 ! the dealer checked it twice and both times the "stupid" thing did'nt make a single sound while at the dealer !
Old Nov 16, 2001 | 07:05 PM
99ITR_SC's Avatar
Default Re: Has anyone ever solved the infamous clutch pedal click? (01-1214)
Mine used to do that as well. It went away after I changed the fluid, but once in a while, I hear a click or two. It sounds almost like a spring from the clutch is catching or something but I dunno
96 ls teg
Sep 5, 2004 10:28 PM
wall of tvs
Jul 23, 2002 12:53 AM
wall of tvs
Jul 18, 2002 09:50 AM
HeelToe
Mar 20, 2002 05:07 PM
