Need opinions on this clutch. . .
Old Jun 23, 2004 | 09:50 PM
EG2 SiR's Avatar
Default Need opinions on this clutch. . .
I know this is the wrong forum, and Ricey or Bauly please feel free to move if necessary. I just felt I would get the best opinions from this area.
So, I was told that my clutch showed "obvious signs of abuse/misuse" after it was removed. It was in my car for 2 weeks and 1000 miles. Tell me what you think the first 2 pictures are a brand new clutch the second 2 are of my clutch. Also, I was told that the blue was caused by "burn" or excessive heat.. but I find that hard to belive since the brand new one shows blue too. Tell me what you think!
Old Jun 23, 2004 | 09:53 PM
Luserkid's Avatar
Default Re: Need opinions on this clutch. . . (EG2 SiR)
Uhh, you sure you showed the pics right? Because the first 2 look better then the 2nd 2.
Also the blue does look like its heating up pretty bad, but im not sure what would cause that.
Edit: What type of pressure plate do you use, also has it been resurfaced?
Old Jun 23, 2004 | 09:56 PM
EG2 SiR's Avatar
Default Re: Need opinions on this clutch. . . (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Uhh, you sure you showed the pics right? Because the first 2 look better then the 2nd 2.
Edit: What type of pressure plate do you use, also has it been resurfaced? </TD></TR></TABLE>
I corrected it, the first two are the new one. It's all on brand new stock parts: pressure plate, tob, flywheel, and disk.
If the bluing is caused by heat, why is the Brand new never installed one blue too?
Old Jun 23, 2004 | 11:23 PM
SICKSOLSI's Avatar
damn ive seen clutches look better after 200000 miles lol...
Old Jun 24, 2004 | 01:16 AM
Junkiii Ek's Avatar
it looks about right to me....i dont think that it would look brand new after 1000 miles.... but they do look a little worn for 1000 miles....hahaha
Old Jun 24, 2004 | 05:10 AM
EG2 SiR's Avatar
Default Re: Need opinions on this clutch. . . (Junkiii Eg)
thanks for the replies. I guess I will have a certified tech. check it out.
snoopaloop986
Jul 17, 2013 02:55 PM
youre_scum
Jul 24, 2006 06:27 AM
x GotBoost x
Honda S2000
Apr 17, 2006 09:49 PM
Tyler_Durden
13
Jun 15, 2003 10:55 PM
Accord_Munch
Dec 17, 2001 12:33 PM
