16 or 18 inch rims on the track
Old Jun 23, 2004 | 07:41 PM
jfingers's Avatar
Default 16 or 18 inch rims on the track
hey guys im going to run my car saturday but i don't know whether to run with my 16 inch sh wheels that weigh 44 pounds each and can't get traction for **** or my 18 inch rims that weigh 41 pounds each a little lighter and have toyo proxy 4's that grip awesome for a launch let me know thanks guys
Old Jun 23, 2004 | 07:53 PM
RAB's Avatar
RAB
Default Re: 16 or 18 inch rims on the track (jfingers)
18's throw your gearing off, i.e. more surface to rotate.
Old Jun 23, 2004 | 07:58 PM
Kal's Avatar
Kal
sh wheels weigh 44lbs each?
Old Jun 23, 2004 | 08:28 PM
RAB's Avatar
RAB
Default Re: 16 or 18 inch rims on the track (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">sh wheels weigh 44lbs each? </TD></TR></TABLE>
Wheels and tires. Come on don't be a dumb *** think about it can a SH wheel really weigh 44 lbs. Idiot.
Old Jun 23, 2004 | 09:20 PM
Kal's Avatar
Kal
Default Re: 16 or 18 inch rims on the track (RAB)
haha wow, i am an idiot now that i think of it lol...Lifting up the tire and I never really thought it was 44lbs... oh well.
Old Jun 23, 2004 | 09:58 PM
Matgallis's Avatar
the rim is about 19lbs by itself
Old Jun 24, 2004 | 04:26 PM
jfingers's Avatar
Default Re: 16 or 18 inch rims on the track (Matgallis)
what am i better off with though?
Old Jun 24, 2004 | 05:35 PM
es_squared's Avatar
16s bro
Old Jun 24, 2004 | 05:43 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAB &raquo;</TD></TR><TR><TD CLASS="quote">18's throw your gearing off, i.e. more surface to rotate.</TD></TR></TABLE>
18's with 215/35/18 rubber is the same diameter of stock so it wouldn't throw gearing off.
That being said if there is only 3 pounds difference I would say go with the 16's just because of the smaller rotating mass and more forgiving rubber cause it's got a higher profile
Old Jun 24, 2004 | 05:46 PM
Kal's Avatar
Kal
Default Re: 16 or 18 inch rims on the track (satan_srv)
I suggest you replace the tires on the 16s first...get something cheap like kumhos...
Old Jun 24, 2004 | 06:30 PM
s2kride's Avatar
r u crazy sh tires come with bridgestone s03 pole positions
Old Jun 24, 2004 | 06:32 PM
Matgallis's Avatar
if the 18's ahve sticker tires, i'd go for the 18's
Old Jun 24, 2004 | 06:43 PM
hOndafienD 04's Avatar
16's and lower tire pressure to about 20....give your traction of a 18" and wont mess up gearing, and will also be lighter, cuz there is less air in it...
Old Jun 24, 2004 | 10:35 PM
alias 33's Avatar
Default Re: (hOndafienD 04)
hondafiend 04 is a dumbass DON'T lower the air pressure to 20!! It will only encourage sidewall roll and will give the car insufficent grip in the corners and only the edges of the tires will grip the road instead of the whole tire would if it were fully inflated. Inflate your tires to recomended pressure and use some white shoe polish and put it on six or eight spots around the tire's edge and drive the course to see how much sidewall flex/rollover you are getting and adjust the pressure accordingly. And use the 16's with good tires.
to hondafiend 04 for giving fucked up advice
Old Jun 24, 2004 | 10:54 PM
Matgallis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">16's and lower tire pressure to about 20....give your traction of a 18" and wont mess up gearing, and will also be lighter, cuz there is less air in it...</TD></TR></TABLE>
Bhahaha air....
Old Jun 24, 2004 | 11:06 PM
92LudeSI's Avatar
Default Re: (alias 33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alias 33 &raquo;</TD></TR><TR><TD CLASS="quote">hondafiend 04 is a dumbass DON'T lower the air pressure to 20!! It will only encourage sidewall roll and will give the car insufficent grip in the corners and only the edges of the tires will grip the road instead of the whole tire would if it were fully inflated. Inflate your tires to recomended pressure and use some white shoe polish and put it on six or eight spots around the tire's edge and drive the course to see how much sidewall flex/rollover you are getting and adjust the pressure accordingly. And use the 16's with good tires.
to hondafiend 04 for giving fucked up advice</TD></TR></TABLE>
I think he is talking about the drag track.
Old Jun 24, 2004 | 11:53 PM
bad-monkey's Avatar
Default Re: 16 or 18 inch rims on the track (s2kride)
depending on the tires, the 16's will be better.
moment of inertia, kids!
Old Jun 25, 2004 | 04:01 PM
Default Re: (92LudeSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LudeSI &raquo;</TD></TR><TR><TD CLASS="quote">
I think he is talking about the drag track.</TD></TR></TABLE>
thank you i was talkign about drag, cuz dats what some1 mentioned so **** you and **** your mom! *******...
Extreez
Dec 25, 2007 12:02 AM
Djole_V
Nov 6, 2007 11:26 AM
Thirty-Nine
May 18, 2005 02:36 PM
JimmyAtlantis
Mar 12, 2004 11:02 PM
01-1293
May 8, 2003 05:55 AM
