what causes clutch chatter?
Old Jun 23, 2004 | 07:29 PM
danny98r's Avatar
Default what causes clutch chatter?
i had an experience with my clutch when my mechanic installed it. i was installing a CM stage 3 clutch on to my CM flywheel that i already had in there. when i got it out of the shop i notice there was severe chatter . this happened for a while until i got sick of it. it made me go back to stock flywheel and and clutch. my mechanic noticed grooves or hotspots on the CM flywheel so could that be a reason for the chatter. do u think the disk and pressure plate is fine. my stock clutch now is losing its grabing power and i wanted to try out my CM clutch again. i will be using the stock flywheel with the CM clutch. this clutch only has 500 miles on it. do u think i should just buy a new clutch even though this clutch is still pretty much new. my funds arent that good but i need some advice
Old Jun 23, 2004 | 07:43 PM
julow's Avatar
Default Re: what causes clutch chatter? (danny98r)
just use your stock clutch the way it is. But i'm thinking your chatter is coming from either the pilot or throw out bearing. Did you change both of these when putting in your CM clutch and pressure plate?
Old Jun 23, 2004 | 07:45 PM
cleggboy's Avatar
i also have this problem i have a clutchmasters stage 2 with CM flywheel and have teh same problem . i changed the pilot bearing and throw out bearing.
Old Jun 23, 2004 | 08:00 PM
igyloo's Avatar
my brother had the same clutch...and same problems: chatter and slight hot spots...but the clutch worked just fine
Old Jun 23, 2004 | 08:21 PM
JiggyKooAndy's Avatar
Default Re: what causes clutch chatter? (igyloo)
what exactly is chatter?
Old Jun 23, 2004 | 09:42 PM
MiraiZ's Avatar
Default Re: what causes clutch chatter? (JiggyKooAndy)
clanging sound coming from the bottom of your car when the clutch is engaged.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JiggyKooAndy &raquo;</TD></TR><TR><TD CLASS="quote">what exactly is chatter?</TD></TR></TABLE>
Old Jun 23, 2004 | 11:12 PM
Bbasso's Avatar
Default Re: what causes clutch chatter? (MiraiZ)
Oh and I thought you were going to bust out a very detailed post about clutch chatter.
Old Jun 23, 2004 | 11:18 PM
Bbasso's Avatar
Default Re: what causes clutch chatter? (Bbasso)
try this for an explanation...
http://www.btc-bci.com/~billben/clutch.htm
OR
http://www.babcox.com/editorial/bf/bf50332.htm
OR
http://www.carcarecouncil.org/...shtml
and if that does not help, try google and type in clutch chatter
Old Jun 23, 2004 | 11:22 PM
chris408's Avatar
hey I just got my clutch installed today, and im getting that chatter noise also on my act clutch and flywheel. It only happens when i Accelerate in 1,2,3. Im hoping it goes away pretty soon.
BUMP
Old Jun 24, 2004 | 05:29 AM
ericlee303's Avatar
Default Re: what causes clutch chatter? (chris408)
I thought that clutch chatter was caused by a mis-aligned pressure plate. You can mis-align a pressure plate if you don't properly tighten the pressure plate to the flywheel.
I had clutch chatter on a stock friction plate once but it eventually went away.
Old Jun 24, 2004 | 06:11 AM
danny98r's Avatar
Default Re: what causes clutch chatter? (julow)
yeah it came with a new throw out bearing. its weird that alot of u guys are experiencing this too. its a sprung disc and should not chatter so i just hate it when it does. the pressure plate was aligned properly cause my mechanic does great work. just trying to figure out if it was the CM flywheel caussing this?
Old Jun 24, 2004 | 06:15 AM
danny98r's Avatar
Default Re: (cleggboy)
did it go away after changing the throw out bearing and pilot bearing??????
Old Jun 24, 2004 | 06:20 AM
Mugen Mike's Avatar
Did you have the flywheel re-surfaced when you did the clutch?
Old Jun 24, 2004 | 06:23 AM
danny98r's Avatar
Default Re: what causes clutch chatter? (Mugen Mike)
no u cant resurface a CM flywheel at least i dont think so.. is it always necessary to resurface a flywheel when u install a new clutch??????
Old Jun 24, 2004 | 06:26 AM
Mugen Mike's Avatar
It's not necessary to re-surface, but it is a good idea.
Old Jun 24, 2004 | 09:17 AM
gblaue's Avatar
Clutch chatter is usually caused by a bent disc. If you are not careful when sliding the transmission back in, it is very easy to bend the disc. The input shaft needs to go in straight, and the transmissionneeds to be well supported. If is not, the disc will be bent and cause chatter.
Old Jun 24, 2004 | 09:33 AM
Type_R_Glenn's Avatar
Default Re: what causes clutch chatter? (00ITR#756)
I had the same problem when I installed my 4 puck ACT clutch and streetlight flywheel... only my chatter is more of a small sqeeking noise almost sounds like im peeling out...... Got annoying and went back to stock...
Old Jun 24, 2004 | 09:49 AM
H-PIMP's Avatar
Default Re: what causes clutch chatter? (Type_R_Glenn)
I don't know about chatter in light organic clutches like stock or stages 1 & 2 CM/ACT. But I had a bronze ceramic 4 puck stage 4 in my R, with a resurfaced ITR flywheel and that puppy chattered badly at first and eventually went away 75% Just light chatter at engagement from there on, but boy did it grip. Slippage wasn't even in it's vocabulary.
Just for the record, chatter in a heavy race style clutch is not an indcation of improperly installed parts, it's totally natural.
Old Jun 24, 2004 | 12:15 PM
chris408's Avatar
Default Re: what causes clutch chatter? (H-PIMP)
Good info guys. I was thinking too, that it was bad installation, but the mechanic who did mines is really good, so I was a bit confused. But if its natural then im not worrying, my chattering isnt that loud either.
Brandon H.
Nov 18, 2012 09:14 AM
an2ny888
Transmission & Drivetrain
Sep 7, 2010 08:58 PM
Extreez
Feb 13, 2007 10:48 PM
SSJSubgeta
Oct 22, 2005 12:20 PM
vishyncsu
Oct 7, 2004 10:38 AM
