5th Gen Master Cylinder Brace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm »</TD></TR><TR><TD CLASS="quote">asdfasdfasdfadfasdf</TD></TR></TABLE>
huh?
As far as the MC brace, I think there might be a JDM after market one around for the Prelude Type S, but seeing as how it's RHD it might not be able to be modified to fit the USDM Prelude. I'd just consider getting something custom made if you really want one.
huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdb »</TD></TR><TR><TD CLASS="quote">
huh?
As far as the MC brace, I think there might be a JDM after market one around for the Prelude Type S, but seeing as how it's RHD it might not be able to be modified to fit the USDM Prelude. I'd just consider getting something custom made if you really want one.</TD></TR></TABLE>
asdasdf = quick bump lol
there has to be one out there....
huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker »</TD></TR><TR><TD CLASS="quote">junkyard?
http://www.car-part.com</TD></TR></TABLE>
i doubt it, mc brace is an aftermarket item, it doesn't come factory or anything...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">i think i saw a thread in autox forum about how bad they are for suspension and useless? something about it pushed on the shock tower and moves it, not sure, mebbe you wanna look into it a bit?</TD></TR></TABLE>
most mc braces i've seen sit on the driver side wheel well and under the strut brace.
Well I looked for them a little while, and only saw the ones for civics and integras.
Is there a specific Prelude brace, or is it possible to use one of those other two and drill your own mounting holes? They are made to fit some bolt pattern on the other cars.
And they did look to be installed on the wheel well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jagan’92 »</TD></TR><TR><TD CLASS="quote">Well I looked for them a little while, and only saw the ones for civics and integras.
And they did look to be installed on the wheel well.</TD></TR></TABLE>
if the master cylinder for the prelude is the same as the teg/civic chassis I'd most definitely use it but i dont think they are...otherwise they would list the prelude chassis
http://www.evasivemotorsports....MC-BR
Wow! I didn't know there was any aftermarket ones. You'll probably have to make one yourself. Its not very hard. 2 1/8" galvanized steel brackets, couple of nuts and bolts, and threaded stock with nuts on it to press against the mc. I have a write up saved from someone who made one for their Teg but their site doesn't exsist any more. PM me your email addy and I'll send it to ya. I doubt it would mess up your suspension though. You only press about 140-170lbs on the brake pedal. If that causes suspension problems then you got much bigger problems than just that.
dohcem1
May 6, 2008 08:50 AM
RacerBoy
May 26, 2003 10:55 PM
