How To Determine Quality Of Pre-Fabbed Subwoofer Boxes
Old Jun 23, 2004 | 02:48 PM
Pworld's Avatar
From: somewhere in INGLEWOOD chillin in tha hood, CA
Default How To Determine Quality Of Pre-Fabbed Subwoofer Boxes
Im looking for a pre-fabbed sub box for my 2-10's. I have looked at such brands as Q logic and OBCON. and they seem nice and strong. But they are on the net. So im going to go around to local shops and look for a box.
How do i tell if the box is made out of MDF and what thicnkess??
What do i look for??
Can i knock on it and tell by the sound??
Can i tell by how heavy it is??
I need some tips. To be a smart consumer
Old Jun 23, 2004 | 03:37 PM
Auex's Avatar
Default Re: How To Determine Quality Of Pre-Fabbed Subwoofer Boxes (Pworld)
Honestly, just about all pre-fab boxes are junk. You can tell if it is MDF just by looking inside it, if it looks like wood chips glued together then it isn't MDF. If it looks like sawdust glued together then it is MDF.
Old Jun 23, 2004 | 06:01 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pworld &raquo;</TD></TR><TR><TD CLASS="quote">Im looking for a pre-fabbed sub box for my 2-10's. I have looked at such brands as Q logic and OBCON. and they seem nice and strong. But they are on the net. So im going to go around to local shops and look for a box.
I need some tips. To be a smart consumer </TD></TR></TABLE>
Of the pre-fabbed boxs I have used the Q logic is by far the best, I haven't seen the OBCON so I can't say if its better or worse.
How heavy the box is, will tell you how good the MDF is, most use 3/4" MDF.
But evan the best box can be made to sound better.
1- seal inside of box , just painting will help, a spray "dynamat" is better, and the best is to use fiberglass resin,then a spray "dynnamat".
2- bracing [if your doing this, do it before sealing] glue in 1"x1"x1.5" MDF or hardwood braces along all the inside edges every 3 or 4 inchs.
If its a large box it also helps to brace front to back and top to bottem useing
1"x2"x ? MDF.
3- cut carpet out from under sub mounting lip, makes a crappy gasget.
Most pre-fabbed boxs will be to big for your subs [air space] so with bracing you can use up air space to match what your subs need.
hope this helps. 94
Old Jun 24, 2004 | 12:29 AM
Pworld's Avatar
Default Re: How To Determine Quality Of Pre-Fabbed Subwoofer Boxes (fcm)
Thanks, maybe i will look for a good quality pre fabbed box. and beef it up a little bit. The reason im not getting a box made, is that my Xtant subs cost me 80 bucks for the pair(10 inch). I want to see how they sound, before i invest the money in having a box built. The largest size recommended is 1 cubic foot per sub. And thats the space i want them to have, so i can get them to play as deep as possible. The Q logics, medium sealed box for 10's states 1 cubic foot per sub. So i might just play it safe and go with the Q
martyball619
Audio / Security / Video
Jun 28, 2007 08:02 PM
nystateofmind27
Sep 29, 2005 12:25 PM
zumiez007
12
Dec 2, 2004 01:14 PM
Black00Civic
Sep 30, 2004 03:41 PM
deeweezy
Jul 8, 2003 12:42 PM
