My new crx
Thank you to streetneeds.com for hosting these pics
Plans...
Full WW kit with whale tail in the mail CF sun roof panel in the mail Tein Basic's putting my meshs from my old CRX on it. I am nto sure on the front seats yet but I am replacing them. b16 when the outside and inside are done. CF mirrors CF door pillar molding Skunk 2 short shifter And other goodies as I go along. I will keep this updated as I go.
Far from a 90 day project
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stk crx »</TD></TR><TR><TD CLASS="quote">Yes stock d16a6 under the hood
The steering wheel is the CANIDAN(sp?) Steering wheel. </TD></TR></TABLE>
Interesting about the steering wheel...
Because I'm almost 100% sure that's a JDM EG non SRS steering wheel.
I thought the EF and EG used different size steering hubs?
Like in my previous post..
That steering wheel is a 92-95 JDM Civic non-SRS steering wheel! I believe it's actually the SiR wheel.
They're really sweet...especially the leather wrapped ones.
How much closer to the driver are the EG wheels compared to the EF wheels?
Is there a noticeable gap at the steering column? I'm way interested in this!
The non-SRS steering wheel is supposedly from a 92-95 JDM Civic. I purchased it off ebay.
Just like this one.
It fits on the CRX but when unmodified, you can only tighten the bolt half a turn. So I took a dremel to the "stem" and cut it off so it was flush and now it bolts on properly. To make the horn work, I used the metal clip that was attached to the OEM CRX steering wheel. Took some time to get the horn to work right, for a little bit, I'd turn the wheel and the horn would honk. Works just fine now, and like you said, looks much better.
Just like this one.
Also, the floormats are virtually one of a kind.........
I had coordinated a floormat deal with Roadworks Auto to produce OEM-like floormats about 6 years ago. Sent them a set of OEMs to duplicate, but they couldn't put the stripe in them. They managed to make a few sets with the CRX logo and "H" emblem before Honda Motors stopped them due to copyright infringement laws. This was the first set they had made.
These floormats are a little bigger in size, which is good since they cover up more floorspace, and they are also thicker.
Roadworks Auto still makes these floormats, but without the OEM logos. They don't advertise it on their website, but they still make them if you ask.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mood »</TD></TR><TR><TD CLASS="quote">The non-SRS steering wheel is supposedly from a 92-95 JDM Civic. I purchased it off ebay.
Just like this one.
It fits on the CRX but when unmodified, you can only tighten the bolt half a turn. So I took a dremel to the "stem" and cut it off so it was flush and now it bolts on properly. To make the horn work, I used the metal clip that was attached to the OEM CRX steering wheel. Took some time to get the horn to work right, for a little bit, I'd turn the wheel and the horn would honk. Works just fine now, and like you said, looks much better. </TD></TR></TABLE>
This is awesome! How does the steering wheel fit against the stock column? Does it have the clearance problem that the Prelude steering wheel has? Or is there a noticeable gap between the steering wheel and steering column cover?
Just like this one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hob20hb »</TD></TR><TR><TD CLASS="quote">well if you dont want all those interior pieces i know some one who does.ME!! i hate not having a full comfortible interior.So let me know if you wanna get rid of any your interior pieces.</TD></TR></TABLE>
sorry. Putting them all back in once the rear seat is welded in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mood »</TD></TR><TR><TD CLASS="quote">Also, the floormats are virtually one of a kind.........
I don't know what you mean by one of kind, I have almost exactlly the same mats, thick black carpet, etc. EXCEPT, my " H crx" is embroidered in red.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c5_motor »</TD></TR><TR><TD CLASS="quote">looks like a great project car.rs*r exhaust i see.i have the same one on my civic coupe.good luck with the work on the car.</TD></TR></TABLE>
RS*R owns. Thank you
Is it Stock under the hood?
