Radiator Fan Relay
Old Jun 23, 2004 | 11:40 AM
spiceisler's Avatar
Default Radiator Fan Relay
Where exactly in the engine compartment is it?
Old Jun 23, 2004 | 11:53 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Radiator Fan Relay (clean90Si)
Do you have A/C?
https://honda-tech.com/zerothread?id=904233
There isn't a relay ifyou don't have A/C
Old Jun 23, 2004 | 11:54 AM
keithv's Avatar
Right behind the passenger side headlight in front of the wheel well.
Old Jun 24, 2004 | 04:50 AM
spiceisler's Avatar
Default Re: Radiator Fan Relay (keithv)
Thanks guys. I do have AC, 4drEF. Anyways I'll look for it. My radiator fan does not come on automatically. I'll check the sensor, relay, and thermostat. The fan does indeed work cause I have it on a separate relay and switch.
Old Jun 24, 2004 | 05:15 AM
keithv's Avatar
Its most likely the relay. I have personally seen 2-3 relays that were bad.
There is a resistor inside that gets corroded and then breaks. This causes the relay to not work. Its a really easy fix, actually.
Old Jun 24, 2004 | 06:27 AM
DieMaster's Avatar
Needs to be About 20% Cooler
my cars 13 years old and I never had to replace anything more than a light or fuse.
Old Jun 24, 2004 | 08:46 AM
keithv's Avatar
Default Re: Radiator Fan Relay (JC18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 &raquo;</TD></TR><TR><TD CLASS="quote">my cars 13 years old and I never had to replace anything more than a light or fuse. </TD></TR></TABLE>
You wouldn't have the problem I mentioned since corrosion on car parts is probably not very high in CA.
hmtcrxsir
16
Apr 9, 2017 11:13 PM
slickrickauto
May 29, 2010 03:01 PM
Nisif
Jan 17, 2006 03:01 PM
92-LS-Civic
Oct 18, 2005 10:09 PM
Dumped DB2
Mar 21, 2005 06:52 PM
