throttle body to fuel injection?
Old Jun 23, 2004 | 11:02 AM
DOZER1160's Avatar
Default throttle body to fuel injection?
how hard is it to change my 89 civic dx hatchback with a throttle body to fuel injeciton? I have the engin wiring harness and manafold and everyyhing under the hood for it but do i need to do anything in the car other then changing the computer?
Old Jun 23, 2004 | 11:16 AM
shawn_crx's Avatar
Default Re: throttle body to fuel injection? (DOZER1160)
Are you talking about changing to MPFI?
If you have all under the hood parts and ECU. Then you're good to go.
plug n play.
Old Jun 23, 2004 | 11:39 AM
DOZER1160's Avatar
Default Re: throttle body to fuel injection? (shawn_crx)
but there are to many wire plug ins on the fuel injection harness then i have on my car as far as the wires that go into the car
Old Jun 23, 2004 | 01:03 PM
Sean_b's Avatar
I have a 91 civic dx hatch, that i just got an engine for with a throtle body(i believe si) any chance you would want to sell your harness that works on the throtle body or trade for one that works with f/i?
Old Jun 23, 2004 | 01:06 PM
4drEF's Avatar
Keyboard Humorist
For electical you just need to do the wiring, change out distributors, add resistor box, and change out the ECU.
Mechanical changes are only the complete intake manifold from throttle body, sensors, and injectors.
You can also change out the cam as well for a bit more power.
Old Jun 23, 2004 | 01:13 PM
jayjay's Avatar
first off let me ask... Are you talking about wanting to change your dual point fuel injection (dpfi) to the multi point fuel injection (mpfi) that's usually found in the SI?
If that's it then you better use the search.....
Old Jun 23, 2004 | 02:02 PM
DOZER1160's Avatar
Default Re: throttle body to fuel injection? (jayjay)
no i my car has a throttle body and i want to put the pgmfi fuel injection with the four seperate injectersoff an hf crx
Old Jun 23, 2004 | 02:13 PM
jayjay's Avatar
so you got this....
and you want this....
Or am I wrong?
Old Jun 23, 2004 | 02:48 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
throttle body is aka dpfi..
Look in the frequent asked questions or "FAQ" at the top of this forum..
There are several links there..
Old Jun 23, 2004 | 02:56 PM
drussell4801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOZER1160 &raquo;</TD></TR><TR><TD CLASS="quote">no i my car has a throttle body and i want to put the pgmfi fuel injection with the four seperate injectersoff an hf crx</TD></TR></TABLE>
for future reference, yoru car is the dx model, which we call 'dual point injection' , or 'DPFI' .. it is still considered PGMFI. it is still considered fuel injection, though you can make the argument that it is 'throttle body injection'.
it has one injector for two of the cylinders and another injector for the other two.
the other type, which you called PGMFI, is called "multi point fuel injection" , or 'MPFI'... it has one injector for each cylinder.
with <U>AMERICAN</U> crx's:
all dx models are DPFI
all hf and si models are MPFI
see above for info on changing over from dpfi to mpfi, or do a <U>SEARCH</U>.
Old Jun 23, 2004 | 03:49 PM
DOZER1160's Avatar
thats excatly what i want to do and thats what i have
Old Jun 23, 2004 | 04:04 PM
go to top right of page and click on search
then under 'Search For' type in 'dpfi to mpfi'
then go to the right and click on archived content
then hit enter
i just did it and it returned 136 results..
ALL THE INFO YOU NEED
weed through all that and if you still have any questions, come back to this thread and we'll try to help. Good luck.
Old Jun 23, 2004 | 04:12 PM
jayjay's Avatar
Default Re: throttle body to fuel injection? (drussell4801)
I tried to tell him, but he didn't want to read the post... so I went back to the basic picture and he admitted that he didn't know what the hell he was talking about....scab....
Old Jun 23, 2004 | 04:13 PM
he's new, you just gotta spell it out the first few times
Old Jun 23, 2004 | 04:15 PM
jayjay's Avatar
thick as a brick....
Old Jun 23, 2004 | 04:36 PM
geez guy
anghel412
Aug 16, 2006 11:13 PM
na91hatch
Apr 1, 2006 03:44 PM
SiMateoAko
Aug 11, 2005 02:52 PM
