hf ecu on a d16y7
Will running a hf ecu on a civic with a 96 y7 motor make the motor run like ***
I have a hf running my car untill i can get a si and my car is making lots of noise and i dont no what it is also throwing a code 13 and i dont have a egr valve?
Si
I have a pm6 but when i turn it over it floods my car with gas
So i am gonna pick up a pm6 tonight and hope it fixes my problem
The motor sounds like it is knocking and **** and i hope its from the ecu
Missing EGR won't make it run "that" bad. you can take it off your HF motor, plug it in and just let it hang there. you may have to run a vacuum line to it as well so it "works", but you won't need it one the intake manifold. That will clear your code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">and yes, it will run like POOP. What dist are you using?</TD></TR></TABLE>
You [b]need[/b[ the HF dizzy for the HF ECU.
You should seriously consider getting a PM6 ECU from a Civic/CRX Si. That will be a better match to your engine than what that economy HF ECU is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">The hf dizzy and the si dizzy are exactly the same..
Yes it is.
But - the D16Y7 dizzy is not... he has the Y7 engine.
Yes it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">
Yes it is.
But - the D16Y7 dizzy is not... he has the Y7 engine.</TD></TR></TABLE>
Correct..
Yes it is.
Correct..
tgreaves
Aug 23, 2003 01:07 AM
allmotorEG-SI
Mar 31, 2002 12:34 PM
