Seat Belt Buzzer - Need to disable
Old Jun 23, 2004 | 06:26 AM
fastball777's Avatar
Default Seat Belt Buzzer - Need to disable
My seat belt buzzer will not go off on my 91 Civic. The seat belt itself works good.
But the buzzer stays on.
I want to DISABLE the buzzer -- is there a way to do this
THANKS FOR YOUR HELP!!!!
crx_88_si's Avatar
the seat belt buzzer is two wires that get disconnected when the belt is buckled.
Old Jun 23, 2004 | 06:31 AM
crx_88_si's Avatar
Default Re: (crx_88_si)
Old Jun 23, 2004 | 06:44 AM
agCrX's Avatar
Its pretty simple, i have mine taken out, all you do is just un-plug that harness under the seat
Old Jun 23, 2004 | 07:10 AM
APEX CRX's Avatar
Default Re: (agCrX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agCrX &raquo;</TD></TR><TR><TD CLASS="quote">Its pretty simple, i have mine taken out, all you do is just un-plug that harness under the seat</TD></TR></TABLE>
yup
Old Jun 23, 2004 | 10:12 AM
Mr.Saturn's Avatar
Default Re: (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">yup</TD></TR></TABLE>
Not always, I don't know if the deciding factor is trim level, year or what, but sometimes this will make the buzzer go constant. The only way to disable it at this level is pull the harness out of the circuit board with the buzzer (or break the buzzer off). On a CRX this is between the sun visors, on a civic, check a manual. After doing this you can also pull the cluster bulb for seatbelt if that bothers you.
Old Jun 23, 2004 | 10:33 AM
crx_88_si's Avatar
Default Re: (Mr.Saturn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Saturn &raquo;</TD></TR><TR><TD CLASS="quote">
Not always, I don't know if the deciding factor is trim level, year or what, but sometimes this will make the buzzer go constant. The only way to disable it at this level is pull the harness out of the circuit board with the buzzer (or break the buzzer off). On a CRX this is between the sun visors, on a civic, check a manual. After doing this you can also pull the cluster bulb for seatbelt if that bothers you.</TD></TR></TABLE>
for CRX... 88-89 belt light is on the cluster, 90-91 is on the rear view mirror.
Old Jun 23, 2004 | 11:39 AM
riceburners1's Avatar
/\ /\ /\ same thing with the civics
Old Jun 23, 2004 | 11:50 AM
phan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">
for CRX... 88-89 belt light is on the cluster, 90-91 is on the rear view mirror.</TD></TR></TABLE>
actually, i think the belt light is in the 90-91 cluster, too. the buzzer, as mr. saturn pointed out, can be disconnected between the sun-visors, in the little box the rear view mirror goes into (also has 2 seat-belt lights).
Old Jun 23, 2004 | 12:52 PM
Mr.Saturn's Avatar
Default Re: (phan)
on the 90 at least, theres a light in cluster and between visors, buzzer is between visor
DSMpolska
Sep 15, 2008 04:24 PM
goodvibe
Honda Fit
Nov 25, 2006 01:47 PM
suprmods
19
Oct 21, 2005 12:07 PM
lucasm1
Apr 18, 2005 09:08 PM
sambam27
Nov 19, 2003 10:47 PM
