vacumn
Old Jun 22, 2004 | 11:04 PM
david90's Avatar
Default vacumn
What is the role of vacumn in a car? How does leaky vacumn affect performance?
Old Jun 23, 2004 | 05:20 AM
JimBlake's Avatar
Default Re: vacumn (david90)
When the engine's sucking air in thru the intake manifold, that makes a partial vacuum in the manifold. Especially if you don't have the throttle wide-open.
You don't want air leaking into the manifold everywhere, only the air coming in through the throttle. The ECU 'knows' about that air, so it injects the right amout of fuel...
Old Jun 23, 2004 | 12:29 PM
jackstands's Avatar
That's one function, but your brake booster and your emissions controls work off of vacuum.
Old Jun 23, 2004 | 01:10 PM
david90's Avatar
right on. How does emission controls work off of vacuum?
Old Jun 23, 2004 | 04:42 PM
Chiovnidca's Avatar
Default Re: (david90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">right on. How does emission controls work off of vacuum?</TD></TR></TABLE>
The MAP sensor monitors vacuum. The ECU makes adjustments based on the reading of the MAP sensor.
Old Jun 23, 2004 | 05:34 PM
david90's Avatar
Default Re: (Chiovnidca)
Old Jun 25, 2004 | 08:03 PM
taz77's Avatar
New User
your fuel pressure regulator works off of manifold vacuum... the evap system checks for leaks by monitoring pressure and vacuum within the evap system... some egr valve uses ported vacuum and some uses a vacuum in the exhaust stream...
Old Jun 27, 2004 | 02:25 PM
david90's Avatar
what are the methods of tracking down leaks?
Old Jun 27, 2004 | 07:10 PM
taz77's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">what are the methods of tracking down leaks?</TD></TR></TABLE>
there are usually 3 solenoids in the evap system. the ecu will open and close these in certain configurations. i.e., the purge solenoid will be open and the vent and anti drain-back (or something like that... the one that prevents vapor from reentering the gas tank...) will be closed. when the fuel vapor is purged from the system, it creates a small vacuum in the system. the purge solenoid will close and the system will/should hold the vacuum. there is a pressure differential sensor within the system that'll detect whether the vacuum is remaining steady.
unfortunately, if there is a leak, a code will be set, but it will not tell where the leak is.
Fitz Williams
Aug 2, 2015 06:06 AM
LUKE 92 GS-R
Jun 18, 2008 06:17 PM
backwoodsman
Mar 26, 2007 07:03 AM
racer_X_123
Sep 1, 2004 04:50 PM
SilverIntegra
Apr 16, 2002 11:32 AM
