Do I have a EGR valve?
Old Jun 22, 2004 | 10:54 PM
lillthingz's Avatar
Default Do I have a EGR valve?
Ok so i took my car in for inspection today and my car failed the Nox BAD like almost 2 times the limit. They said to replace my EGR valve, but however I can't find it. Like it is supposed to be located by the intake manifold according to my Haynes manuel. But i can't find it. I have a 92 SI hatchback with the stock D16Z6. Am i supposed to have this valve or what? Someone help me please..
Old Jun 22, 2004 | 11:01 PM
=GAME='s Avatar
Default Re: Do I have a EGR valve? (lillthingz)
you dont have it on that motor.
Old Jun 22, 2004 | 11:03 PM
lillthingz's Avatar
Default Re: Do I have a EGR valve? (=GAMEOVER=)
If i don't have a EGR valve than do you know what could be causing my nox level to be so high?
Old Jun 22, 2004 | 11:07 PM
=GAME='s Avatar
i have no idea but i believe the EGR valve only came on vx between 92-95.
Old Jun 22, 2004 | 11:10 PM
phobi9's Avatar
I thought only OBD2 96+ cars had an EGR system, but I could be very easily wrong. The EGR system only flows tiny tiny tiny amounts of exhaust gas back into the intake at certain times (depending on if you are full load, wot, rpms, etc). If you're spitting out too much NOx then that should be because of your cat, right?
what's every1 else think
Old Jun 22, 2004 | 11:13 PM
lillthingz's Avatar
I see, thanx for the information. Tommorow I am going to go up to jiffy Lube and tell them to find my EGR valve hahaha. I told them I didn't have one. I wanna see those idiots look for it. HAHAHA I heard that it was because of the CAT. So 'll just get a new one i guess.
Old Jun 22, 2004 | 11:14 PM
stockegsix's Avatar
you dont have an EGR
Old Jun 22, 2004 | 11:22 PM
lillthingz's Avatar
Default Re: Do I have a EGR valve? (stockegsix)
Oh I also forgot to ask, I heard that my co and nox levels can be messed up because my timing could be off. Is this possible?
Old Jun 23, 2004 | 02:20 AM
4g4drb17's Avatar
they don't smog me in san antonio, why are they smoging you in tx
Old Jun 23, 2004 | 05:56 AM
Jokerluv's Avatar
Default Re: Do I have a EGR valve? (4g4drb17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4drb17 &raquo;</TD></TR><TR><TD CLASS="quote">they don't smog me in san antonio, why are they smoging you in tx</TD></TR></TABLE>
DFW smog tests suck
my VX has an EGR
Old Jun 23, 2004 | 06:02 AM
93CivicSI's Avatar
Not on that generation -
Old Jun 23, 2004 | 06:05 AM
93CivicSI's Avatar
Nox can be bad due to poor ignition timing - or your cat is going bad...
Deemeetree's Avatar
Electrician
Wow, there is no smog down here in South Texas. I believe only the VX models have an EGR valve as stated above.
Old Jun 23, 2004 | 06:47 AM
93CivicSI's Avatar
And possibly a vacuum leak - allowing excess air into the intake system..
PCV valve
Old spark plugs...
There are many many contributors
Old Jun 23, 2004 | 06:50 AM
monicle's Avatar
the HX also has an EGR valve.
Old Jun 30, 2004 | 08:30 AM
gotjesus's Avatar
Default Re: Do I have a EGR valve? (monicle)
i also am failing due to high nox levels .i have a 94 cx hatch.. with a gsr...i have a stock new cat, 02 sensor is hooked up, however, i dont know if im running lean or rich though. i also need help with getting my car to pass. so my car does not have egr either?
d16dcoe45
Jul 28, 2005 01:54 PM
Cyber ITR
Nov 21, 2004 06:26 PM
MrFingerz1
May 17, 2002 07:17 AM
Evil DOHC
Sep 24, 2001 04:36 PM
