Whats the highest you're boosing in your JRSC kit ??
Old Jun 22, 2004 | 10:48 PM
RuffGsR's Avatar
Default Whats the highest you're boosing in your JRSC kit ??
-What is the highes you know a JRSC kit is able to boost up to ?
I know JR has a new pully that can put you in the 12psi, So I'm assuming you can go up to 14psi or so now, By upgrading / replacing the Crank pully and the alternator pully...
I'm about to get my motor built and I wanna keep the super charger, But I just wanna boost as much as possible... I dont like turbo that much
Old Jun 23, 2004 | 03:14 AM
dash's Avatar
Default Re: Whats the highest you're boosing in your JRSC kit ?? (RuffGsR)
well i am running 9psi, i would suggest running a more aggressive compression then stock and look into a bigger blower like m62. and a after cooler. BTW what is your set up at the moment i am having some problems withe mine (heat soke i think 85 degree temps dont like my set up now)
and try http://www.theoldone.com/
http://www.lhtperformance.net/
Old Jun 23, 2004 | 03:21 AM
diulay_pkjai's Avatar
To run 12+ psi you will need an water to air intercooler or do alcohol injection, cuz the blower will heat up the air a lot at that high boost.
Old Jun 23, 2004 | 06:43 AM
ATgrills.com's Avatar
Default Re: (diulay_pkjai)
Im running 11-12 but I have a spearco water cooler to help keep the temp down!
protopro88
Apr 7, 2011 09:14 PM
Akura
May 16, 2005 06:50 PM
redsidriver
Dec 27, 2003 04:23 PM
siis2fast
Jun 25, 2003 09:22 AM
Tru Dynamix
Apr 30, 2003 10:33 AM
