Coolant Temp switch question
I have JDM B16A and I, in a lapse of paying attention, did not see which wire came off of which prong. One is black and I believe the other is yellow/red. anyone know which plug goes on which prong?
CORRECTION: It's yellow/green not yellow/red
Needs to be About 20% Cooler
dont hold me accountable on this; i'm not sure but i think the yellow/green goes to the ecu temp sensor.
hang on are you talking about the fan thermostat or the temp gague / ecu sensor combo.
That's the wiring diagram I guess I'm confused is the switch on the diagram the same as if I was looking at it on the block? If so then that would mean I would plug my yellow/green wire onto the top prong and my black wire onto the bottom?
My skills at reading wiring diagrams are getting better but are still crap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv »</TD></TR><TR><TD CLASS="quote">It doesn't matter how you connect it up as it will work regardless.</TD></TR></TABLE>
Fair enough! Thanks
Fair enough! Thanks
cluelessmale
Jun 5, 2011 09:14 AM
tibss
Jan 31, 2008 11:28 PM
shortdahri
Dec 31, 2005 12:48 AM
