Differences in EG and EF
wondering if any one knows if the sway bars will exchange and what the differences in the rear Lower control arms and so forth....
I am thinking of using a friends old ST rear bar that he has I know the front probably won't work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andzey »</TD></TR><TR><TD CLASS="quote">yeah - co-operation is weak
so it won't work
so it won't work
I'm pretty sure the rear LCA's are very similar. I am using LCA's from 97~01 Integra Type R on my 91. i know that a lot of EG people are using them as well. These LCA's are interchangable with the 88 CRX.
The LCA's aren't going to be the problem with monting the sway bar though. The EG sway mounts to the subframe much differently than the EF/ED. You would have to fab something up IF the EG bar even fits under our cars. EG's are notorious for ripping holes in the subframe when they use a heavier sway. They usually install a Beaks kit to help reinforce the subframe to hopefully prevent ripping out. You would want to do the same if you get the EG bar to fit somehow.
no motor not back yet more stuff getting done
and yes the interior is back together
not the dash yet???
and that is way to show and go
not just show smarty
not the dash yet???
Power Rev Racing
10
Jun 10, 2005 03:06 AM
VSM EXtasy
May 6, 2005 11:56 PM
hionvtecxda6
Mar 26, 2004 07:18 AM
phantom_sol
Oct 14, 2003 09:13 AM
